Nate, my EFI requires 12psi at the injector. If you get a pump that can put
out that much or more (not much more) it should work. I also carry an extra
pump in the event that I need to change it on the road.
al
> Nate, first find out what preasure your fuel injectors should be at.
> Second, go to somewhere like a speed shop and get an electric fuel pump
> rated higher (psi/gal/min) than what you need. You should not have any
> problem getting the correct size.
> Also, while your under there. I installed a hidden dash switch in-line with
> the fuel pump. Even with my unit hot-wired, someone couldn't start it
> without gas !! It's a cheap theft deterrent.
> Scott
> "Nate Chase" on 08/10/99 10:48:22 PM
> Please respond to gmcmotorhome
> To: "GMC"
> cc: (bcc: Scott Milton/GV/Kyrus)
> Groups: Don't Expand
> Subject: GMC: Fuel Pump
> HA!!! It appears to be the fuel pump (or fuel system). I sprayed starting
> fluid on the air cleaner and it ran so good I could even drive up into my
> drveway! Then it dies... Oh well atleast I'm back home and on the right
> track!
> My electric fuel pump musta gotten weak or bad enough to pump gas out of
> the
> line but not enough pressure to feed the throttle body injectors (I
> guess)... sound logical???
> Whats a good replacement? Remember a month back or so a thread on this but
> never wrote it down.
> Nate '75GB Omaha
al
> Scott
> To: "GMC"
> track!
> the
> Nate '75GB Omaha
