Fuel lean-out
gene
2,215
How was the swap meet you luckey duck
gene
>I'm starting to wonder if I'll need to adj the carb because it may lean
>things out a bit too much after all this? Any thoughts?
>Nate,
> I can't tell without an O2 sensor but I believe the coach was/is
>running a bit lean from the gitgo anyway. On loooong grades I can
>actually get more power and lower the engine temp a little by hitting
>the electric fuel pump. So much for supply, the jetting, however, is
>due for a change. Most likely up two jet sizes due to the crap-like
>qualities of that wonderful oxygenated fuel here in CA. One of the best
>Rochester carb guys in the business is here in San Diego and I had an
>opportunity to talk with him Sunday. He pretty much summed up all I've
>read here in the digest and then some. It's going to him soon.
>HTH,
>Steve F.
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
Nate,
HTH,
Steve F.
