Fuel Filters
Fuel filters do serve a real purpose. Fuel is not always clean when it is
delivered to stations, nor are station storage tanks necessarily debris
free. Most pumps do not filter fuel either. So, if you rely upon the carb
inlet filter exclusively to deliver clean fuel, expect it to require
service. Carry spares. If you use an electric auxiliary fuel pump, most of
them require a pre filter as well.
I guess that it comes back to periodic maintenance. Air filters, fuel
filters, lug nuts, tire pressures, lubrication, oil changes, walk around to
check lighting, etc. Pretty necessary on 40 year old vehicles.
Salem, Or
78 GMC ROYALE 403
Seems tanks are either opperating room clean or nasty. If clean, you don't
need add-on filters (added fail or fire risk) and if the tanks are nasty
due to dirt in filter evidence, they need to be dropped and corrected.
John Lebetski
Woodstock, IL
I tend to differ on the non use of the filter, as people tell me their tank
is clean. So we do not addres it when it comes into our shop.
Well, after picking up the coach they call us all upset and wonder whey
they are having fuel delivery problem.
The Aux tank can be the big source of problem as the fuel is not run down
close to empty and gum build up is removed and captured by the filter.
I do not carry hardly any spare parts crossing the Western states other
than a dist. module , coil and filters. Oh, a fan belt.
> Jim Hupy
> Salem, Or
> 78 GMC ROYALE 403
> On Jan 12, 2018 7:07 AM, "John R. Lebetski"
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
http://www.appliedgmc.com
There no such as a clean fuel tank as the fuel being loaded into your tank can have contaminates at any time, including the stuff that get loaded when the gas station storage tanks are low and haven’t been cleaned lately and that happens not as often as you think and the possible contaminated fuel right out other delivery tanker.
In the first coach which was a 77 Eleganza II with a 403 and Paterson Carb and all electric fuel system with mechanic pump removed I ran 2 fuel filters. One before the pump in the back and one before the carb in the front. I also which was my choice to remove the internal fuel filter in the carb. I change the filters in the spring and in the fall. The front filter was moved to the back and the back and a new filter was installed in the front. Twice a year for us because the coach was used year round with trips to Florida or Arizona in the winter. Those of you that store your GMC would only need to replace the filters in the spring.
http://www.gmcmhphotos.com/photos/electric-fuel-pump-26amp-3b-filter/p9898.htmloperating
Our currant GMC is a Buskirk Stretch actual length 29.5 foot long. It has an MPFI with a low pressure and High pressure pumps located back near the fuel selector valves, which were changed recently. The first is a large preflight that also is a coalescing filter to remove any water that may get loaded from the stations tanks. It then is pumped by the Low Pressure Pump (carter P4070) and then to the High Pressure which is our case is a pump used by Mercedes 450SEL then the final filter to the fuel rail and returned to the tank that in comes out of.
J.R. Wright
GMC GreatLakerTech Editor
78 Buskirk 30' Stretch
75 Avion Under Reconstruction
Michigan
> Jim Hupy
> Salem, Or
> 78 GMC ROYALE 403
> Seems tanks are either operating room clean or nasty. If clean, you don't
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
J.R. Wright
GMC Great Laker
GMC Eastern States
GMCMHI
TZE Zone Restorations
78 Buskirk Custom 30' Stretch
> J.R. Wright
> Michigan
> is
> of
> fuel
> to
> > Jim Hupy
> > Salem, Or
> > 78 GMC ROYALE 403
> don't
> > John Lebetski
> > Woodstock, IL
> > 77 Eleganza II
If you have a rubber hose coupling a filter under pressure, your inviting
trouble as we forget that old hose and when it develops a leak, it will
squart and can catch on fire from hot exaust.
Should you placce a filter ahead of the pump, put it right in front of the
pump to avoid vapor lock.
> J.R. Wright
> GMC Great Laker
> GMC Eastern States
> GMCMHI
> tank
> when
> in
> with
> get
> Pump
> returned
> > J.R. Wright
> > Michigan
> > is
> carb
> > of
> > fuel
> around
> > to
> > > Jim Hupy
> > > Salem, Or
> > > 78 GMC ROYALE 403
> > don't
> nasty
> > > John Lebetski
> > > Woodstock, IL
> > > 77 Eleganza II
