Fuel air Ratio Meter
thomas g. warner
1,863
just put a sensor in each side with a switch going to the panel and switch
from one to the other.
>GMCers
>OK here I go again. While going through my Summit catalog I noticed
>They had two different meters to measure the fuel air ratio. Both are
>based on an O2 sensor. The one by Elderbrock looks to be a simple
>meter. The one by MSD has a meter with two lights. Red means you
>are running lean and green means you are running rich. Both on you
>are just right. Both are in the $120-130 range. The problem is that each
>of them just has 1 sensor. Now if we had 2 sensors we could read each
>side of the exhaust. I think this would be very handy. We could tell if our
>tuning was off. If we got some dirt in a jet it would tell us we were lean.
>Then we would know why we are running hot. We know that a stoi
>ratio of 14.7 (I think) yields a voltage of 1. Even a couple of cheap
>voltmeters
>would tell us something. Maybe the guy that builds the digi---what ever
>could come up with something for us. The idea is free for the taking.
>Somebody go build us a cool new toy.
>Take Care
>Arch
Arch:
Westach, http://www.westach.com, 800-400-7024, tells me they have three
different models of a dual air fuel ratio gauge for $68.80.
Paul Bartz
Sent: Wednesday, October 13, 1999 10:39 PM
>GMCers
>voltmeters
>Take Care
>Arch
Arch,
I copied the following report from somewhere on the WWW about a year ago.
Sorry I didn't save the credits.
Don Miller
75 project
Shenandoah Valley of Virginia
O2sensor
I just bought the Edelbrock air/fuel ratio monitor and hears what
I discovered:
Sensor is a Bosch PN E971-9F472-AA .
A lot of numbers stamped on it, but I think this correct Bosch
part number.
I believe this is a standard three wire conventional O2 sensor
though I do not have manufacture's literature.
The "little black box" is nothing more than little and black.
It has a surge suppresser, filter capacitor, a resistor to
control LED brightness, and a LM3914 Dot/Bar Display Driver. The
design is straight from application books with no creativity.
Did I mention the lack of input signal conditioning / filtering
to remove engine / ignition noise?
Given the speed of LM3914 comparators, this is a problem in my
implementation.
The electronics clearly runs sensor in voltage mode drawing only
a 25nA biasing current for LM3914's internal buffer.
The sensor voltage and air/fuel ratio have the following
corresponds:
volts air/fuel Lambda (open circuit)
.250 15.0:1 1.02
.375 14.5:1 0.99
.500 14.0:1 0.95
.625 13.5:1 0.92
.750 13.0:1 0.88
.875 12.5:1 0.85
1.00 12.0:1 0.82
>From what I have read in the SAE Transaction pertaining to O2
sensors, this relationship is "bull shit".
I can not believe this mode of operation would let the sensor go
as low as .8 lambda or have this linearity.
I would have expected Edelbrock to use a current mode of
operation.
My next step is to change to current mode operation.
> GMCers
our
lean.
> voltmeters
> Take Care
> Arch
