Frustrating Weekend Power steering Questions
powwerjon
865
1
The filter of choice in the past was an AC PF-883 Power steering filter.
http://www.gmcmhphotos.com/photos/member-galleries/p63884-power-steering-upgrade.html
That filter is no longer made and is not available, not even on eBay.
There are several that are a good substitutes.
O’Reilly’s: https://www.oreillyauto.com/search?q=991FLT2
Advance Auto Parts: https://shop.advanceautoparts.com/p/cardone-power-steering-filter-20-0038f/10417593-P?searchTerm=power%20steering%20filters
This is the setup that I use along with a cooler as the pump imparts heat into the fluid. The cooler that I have are a Ford flat plate type unit and there are many other available to use.
Cooler Part#
An O’Reilly part#: https://shop.advanceautoparts.com/p/imperial-power-steering-oil-cooler-241009/19230069-p
Autozone part# https://www.autozone.com/filters-and-pcv/power-steering-filter?filterByKeyWord=power+steering+filter&fromString=search&isIgnoreVehicle=false&model=power
J.R. Wright
GMC Great Laker MHC
GMCGL Tech Editor
GMCMI
78 GMC Buskirk 29.5’ Stretch
Michigan
I strongly advise against that Cardone filter from Advance Auto. It
appears identical to the one that caused all of my problems. It contains a
tiny SS screen about 3/8" in diameter.
I also cannot recommend the one from OReilly, which appears identical to
the Edelmann 70700 and AutoZone's Duralast 70702, which I'm running. If
you look at the Amazon 1-Star ratings on the Edelmann, you'll find that 15%
of the customers reporting have rupture or less severe leakage problems
with them -- too much risk for me; I'll be replacing mine soon.
I'll be looking for a large filter with a sealed metal housing, just on
general principles.
> Advance Auto Parts: <
> Cooler Part#
> An O’Reilly part#: <
> Autozone part# <
> J.R. Wright
> GMC Great Laker MHC
> GMCGL Tech Editor
> GMCMI
> Michigan
