Front Wheel Well Liners
marlene meineken
1,859
Can anyone tell me how many of the bolts that come from the top through the
wheel well liners have nuts and washers on them and which ones are used?
"Not talking about the screws on the fiberglass and liner"
Our's GMC came with none.
Marlene
Marlene:
As far as I know, neither of the two bolts you refer to, are meant to support the
wheel well liner. There is only one screw with a washer on it that goes up
through the small hole in the liner into the floor of the coach.
Paul Bartz
Sent: Tuesday, August 15, 2000 8:41 PM
>Marlene
Our 73 came with ONE right in the top of the arch, up from the wheel area
into the
floor,
John & Brenda Szalay
73 GMC "Wild Blue Yonder"
Then the only thing that is holding the liner in is the screws along the
edge of the liner and the fender? One of our liners is out as when we had a
blowout last year the screws were pulled out of the liner. I do see a strip
of aluminum across the top on the plywood which has a threaded screw hole in
it which would line up with the liner where there is an indentation. Does a
screw & washer go here? All the bolts do have washers and nut's on them.
Marlene
> The bolts that come through the liner are the ones that hold down the
> metal base under the seat. They dont hold in the liner. They should
> all have thick washers and a nut on them. You will never need them
> until you have a wreck. Hope that helps. Had to take all of mine out
> to put in insulation and carpet. YES I know I could have left the base
> in----not my style.
> Take Care
> Arch
> To unsubscribe, e-mail: gmcmotorhome-unsubscribe
> For additional commands, e-mail: gmcmotorhome-help
Marlene:
Yes, as I said earlier, the screw going thru the top of the liner and into the
underside of the floor is the only hardware holding it in place.
Sent: Tuesday, August 15, 2000 10:13 PM
Marlene
> in----not my style.
> Arch
Alternatively, you can trim the inside bottom edge of the liner in strategic spots
with a Dremel tool using an abrasive disc and get the same effect.
Paul Bartz
Sent: Tuesday, August 15, 2000 10:12 PM
I found that the liner bangs around and adds to the noise level at times,
especially over rough roads. Soooo, I added several strategically placed
bolts/washers etc. and alls quiet in the wheel well. Dean hanson
