Front Wheel liners
wayne newland
1,588
Contact J R Slayton for a set of stainless steel oil lines. I understand
that a few coaches have lost engines because the oil lines failed. I just
bought a new set from J R. Now to get them installed, before going to
G.E.A.R. Tuesday.
Wayne Newland F9300 75 Palm Beach Columbia, Md (another 10 day)
> GMCers
> Good day today---got a lot done. I do have a question. Have any of
> you repaired your wheel liners. I have several cracks and some
> broken out holes. I am guessing that they are ABS plastic from the
> feel and texture. Can anybody confirm this? Had one he** of a time
> getting them out. I have had them out before so I could not imagine
> why they were so stuck in place. After a good half hour wrestling
> match I found the problem. Earlier this summer had sealed the drivers
> floor to the walls and tried to seal up all of the leaks up front. I had
> sealed
> the cracks with the expanding foam------well the leaks must have
> been really big because the foam got out and glued the wheel well
> liners in place. The way I found the leaks was waited for a very hot
> day. Turned on both ACs on high then turned on the vent-fantastic
> on high exhaling. Not hard to find the hot air coming in. Once all
> leaks were plugged I then turned the vent to inhale and went outside
> to feel the cold air coming out-----sealed a few more on the outside.
> Guess it would work on a cold day too but I still dont have propane
> system up yet. Tuesday I will take the lady in to my friends shop
> to repair the exhaust manifold gaskets. We will make a decision
> on whether to do a valve job. If you remember the lady sat in a junk
> yard for at least 5 years that I know of. I had compression of 165 psi
> down the line except for 2 cylinders at 110 and 114. My call was rusty
> valves. Now I have driven it 150 miles we will take another look. If I
> have to go in this deep then I will be back with a whole bunch of
> questions. Youall be thinking of what I need while I am in there.
> Cam?, got the timing chain ordered----yeah new water pump on
> order---yeah a new fan clutch too. I do need Zeb's number so I can
> get a new oil filler elbow. What else do I need?
> Thats how I glued my front wheel well liners in place.
> Take Care
> Arch 76 GB IL
Arch
A while back, I suggested to someone that had picked up a coach that had sat
for quite a while, that they use a bottle of Wynn's Tuneup to free up the
gums and varnishes on rings, valves and lifters. Before you spend a lot of
money tearing down an engine, go to a company owned Goodyear or Firestone
and purchase a bottle. Pour it in your oil and fast idle for about 10 - 15
minutes. Then take another pressure reading and see if it helped. The
worst thing is that you blew about $5.00. I've seen it work so many times
over the years, and usually the mechanic just stands there shaking his head
(as in "wow"). If you can't find Wynn's professional products in your area,
I'll check with my sources or even send you a bottle.
Wayne Newland (ex-Wynn's rep)
> GMCers
> sealed
> Take Care
> Arch 76 GB IL
