I am assuming that everyone has the same problem that I am having and that
is finding a front bearing puller that works, does not destroy the bearings
and is reasonably priced.
Finally got time to check on producing a good wheel puller/installer for the
front wheel bearings. I have a friend that has a large machine shop full of
CNC machines and have talked him into doing them for me. The set will be
very close to the Winterfeldt set if any of you have seen it. I have found
a source for the OTC 927 bearing puller for $75 + postage (maybe cheaper in
quantities of 10 or more), and already have ordered one and it is nice. This
is a very rugged unit and can be used to pull harmonic balancers etc also.
The rest of the tool set consisting of three pieces, split collar, small
insert for pulling the bearing and another tapped insert for reinstalling
the bearing. From our preliminary discussions he can make the three pieces
for about $100 to include black coating to prevent rust. That would put the
total bearing removal tool at less than $200 including postage.
If I can get 9 others to buy I will place an order with him for 10 units.
Anyone still interested?
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
