Front/Rear Track Dimensions
9675.0203
47
Has anyone actually measured their front and rear track centerlines?
I have a '77 Palm Beach, and the 1977 operating manual states:
Track.....................Front - 75.28 in.
Rear - 82.12 in.
I measured mine and they are not what the manual states. They are:
Front 75.00 in.
Rear 82.75 in.
I have stock steel wheels, and 8.75R16.5 Michelin tires.
Would the Alcoa wheels have a different track width?
This was brought to my attention by the tires not tracking where they
were supposed to when I drove up on a ramp I built for maintenance. The
ramp was built using the "manual's" dimensions .. not much difference,
but enough to be noticeable.
Comments will be appreciated.
HR in Indy
9675.0203
Do you have exactly the same size tires on your coach as those used for the
data, ie; same series?
>In a message dated 10/10/98 5:59:29 PM Central Daylight Time,
> Rear - 82.12 in.
> Front 75.00 in.
> Rear 82.75 in.
>That's interesting. I also have a 77 Palm Beach and have never had the road
>wandering problems so many folks seem to have. Someone mentioned to me once
>that the 77 and 78s had a little different alignment. Maybe that is what it
>is.
>Justin
Yes, same size tires and and stock steel wheels. Tire size should not
affect tire track center-line dimension, as that is measured center-line
to center-line of the tires. A different wheel contour could affect the
center-line position and change the track dimension.
HR in Indy
9675.0203
Date: Sat, 10 Oct 1998 23:07:06 -0400 (EDT)
Subject: Re: GMC: Front/Rear Track Dimensions
> Do you have exactly the same size tires on your coach as those used > for the
> Rear - 82.12 in.
> Front 75.00 in.
> Rear 82.75 in.
> HR in Indy
> 9675.0203
