Front end sag after one-ton install?
Joe Weir
Member
Feb 13, 2013
743
9
18
Back from lurking. Wicked mistress still not having adventures, but more out of my schedule, and not any real needs. Anyway, a little something to
ponder during the lockdown:
There is a thread on one of the facebook groups discussing a run of even stouter torsion bars to compensate for the wider track of the One ton
Conversion.
Gentleman claims that with his new one ton install, and his stock pork chops maxed out, the front end of his 26' is still too low per spec. He has
published calculations that show the stock bar, and even the Huber bars to be inadequate for the loading.
https://drive.google.com/file/d/15U-r7x6edQBsO9Rdexyhc5LSPa9v2jkp/view?fbclid=IwAR0B9XxlNmq2_iTxJF85cltXR2adz77mxeHfiMKgSHkB4CT3QPYS0yk_QCI
There was another person who volunteered they had the same sagging issue after installing a one ton on their 23.
The gentleman is preparing to do a run of even thicker bars - what a great country.
My question to the hive:
Has anyone heard of, or experienced, this issue with the one ton? I don't remember seeing any discussion, and a forum search doesn't show any
either.
It seems to me that if the issue is the 4" increase in arm length, wouldn't this issue have come up with anyone who has put on wheel spacers? Those
have been around forever. Not discounting the math (I am not qualified), just the suddenness, or selectivity, of the problem. Why not everyone?
Why now?
Are stock bars finally getting to the age where they will just not tolerate this foolishness? If the stock bars are not up to the task, I would think
this would have been an issue from the start. Not that the option to be able to purchase even thicker bars is a bad thing, just that my
troubleshooting spideysense is telling me it would have to be something else wrong in the suspension, or torsion bar mounting.
Comments?
76 Birchaven - "Wicked Mistress" - New engine, trans, alum radiator, brakes, Sully airbags, fuel lines, seats, adult beverage center... those Coachmen
guys were really thinking about us second hand owners by including that beverage center...
Columbia, SC.
I've had the same problem I'm afraid. The heavier bars worked but a little more would have been nice. I ended up using some Revcon bars in my Diesel
swap. Too bad they are so hard to come by. They do require a little redo of 'stuff'though. They are slightly shorter requiring the cross member to be
shifted forward slightly and the flats aren't parallel so adjustable pork chops are needed.
Hal
1977 Royale 101348,
1975 Eleganza II, 101230,
Rio Rancho, NM
When I installed Manny's 1-Ton front end, I had a similar problem. In my
case, the solution was simple: Manny had not adequately inspected,
repaired, and reinforced the socket in the Lower Control Arm (LCA) -- it
had "erupted", allowing the hex end of the bar to rotate slightly in the
LCA. On my 23', replacing the LCA with a good one fixed the problem. But,
before that process was completed, I'd learned a lot about the situation:
1. The OEM LCA's design is, IMHO, deficient in that it seats the load
bearing
hex end of the Torsion Bar (TB) in the center of a section of hex tubing.
At each end of that horizontal tube, there is a vertical member (the "fold"
of the A-frame) which would offer a lot of reinforcement of the tube it the
torsion bar hex was seated there.
2. Related to #1., preceding, is a deficient design of the torsion bar
itself: The hex on the end is too short, allowing it to sit, as described
above, in the weakest part of the socket. By extending the hex, the TB
itself can correct for the deficiency of the socket design -- a longer hex
will pick up the reinforced area. IIRC, my comments about this resulted in
the hex being extended on the later after-market TB's.
3. One of the things I was tempted to try before discovering the real
cause of my problem was the use of SuperMax adjustable pork chops. These
two-piece pork chops (sold by Applied GMC) have their hex socket area in a
moveable section which can itself be rotated to multiple positions,
allowing one to change the "angle" of the pork chop. That MAY be
sufficient to compensate for some slightly distorted TB's.
4. While considering the SuspensionMaxx pork chops, I talked by 'phone
with the designer/company owner (Larry Verbowski) about the situation. A
part of that discussion involved that the modern (past few years) of GM
trucks use TB's which are very similar to ours, but 4" shorter and with
slightly different hex sizes (1/4" larger, IIRC). There is a WIDE
assortment of TB diameters available in that design. Of his own volition,
Larry, overnight, designed and built a prototype of an adapter to allow the
current production torsion bars to be used for the GMC. Basically, that
adapter consist of a socket for the 1-1/2" hex with an attached 1-1/4" hex
bar to fit into our LCA. That hex bar is long enough to seat in the two
reinforced areas of the OEM socket, adding significant strength to the
whole arrangement. At the rear end of the TB, the adjustable
SuspensionMaxx pork chops in the 1-1/2" hex would be used. AFAIK, that
prototype was the only one ever made. Immediately after my last
conversation with Larry, I discovered the root cause of my problem and
Manny rectified it (and for subsequent production).
If I needed stronger torsion bars, I get back with SuspensionMaxx, or
otherwise devise the adapter and larger pork chop opening, and take
advantage of the widely available modern torsion bars. NOT have new
old-design bars produced (but if I did reproduce, I'd be sure to have the
longer front hexes included).
JWID,
On Fri, Apr 10, 2020 at 4:36 PM Joe Weir via Gmclist <
> Conversion.
> has
> country.
> either.
> Those
> Why now?
> would think
> Comments?
> Coachmen
> beverage center...
> Columbia, SC.
I tried to get this accomplished a couple of years ago. They were going to send an adapter but never followed through. I tried a number of calls but
finally gave up. I did find the pieces to home brew an adapter but wasn't sure of the strength so just let the effort die. Might try to reinvigorate
my efforts if I get too bored.
Hal
1977 Royale 101348,
Rio Rancho, NM
Thanks for all the input. Very interesting.
I have not monitored the boards that closely, and it appears my google-fu is weak..I missed that altogether.
So, it sounds like there are two issues:
Control arm socket/TB length fatigue and one ton/TB fixes
Insufficient load adjustment on the stock adjusters (pork chops)
So if the TB's are the extended length, and the sockets have been reinforced, then the issue will not be with the LCA.
However with that done. a super pork chop will need to be installed to set correct ride height.
So ...
A. does the extra adjustment on the pork chop exceed the capacity of the TB, or just use more of its untapped potential?
B. Is the issue that the TB is now too soft a spring rate, and does the extended pork chop fix that?
Seems like this would have been an issue with front wheel spacers, Was it just not noticed before?
I have a one ton kit and a set of extended TB's that were in the bullpen waiting for a break in the action to install. Didn't do the math, but
figured 20% stiffer sounded like it would do the trick. Just trying to stock the correct parts to make sure I can finish what I start, when I
start.
Columbia, SC.
Twisting the bar further won't correct the issue. you'll need the 19% bigger bars. The stock bars just don't have the capacity, especially after 40+
years of service. If you have the later version bars they should have the extended ends and 'should' work. Most of the one ton LCA's had the sockets
strapped/strengthened and normally are OK (although I managed to blow one out) but I have quite a bit more weight up front than most. The adjustable
PC's probably won't be necessary 'but' still may be needed. It seems there were possibly 3 different pork chops out there and it will depend on your
particular coach combination.
Good luck, Hal
> So ...
> start.
1977 Royale 101348,
Rio Rancho, NM
Here is a posting in the Photosite where someone (voodooling) used an impact wrench socket to adapt the lower control arm to accept the newer, shorter
torsion bars.
I'm sure there was another guy that did this as well.
Has anyone else done this mod?
BTW, who is voodooling?
Bruce Hislop
ON Canada
Tim Petras in Colorado. I think he's moved on from GMCs now.
-----Original Message-----
From: Gmclist On Behalf Of Bruce Hislop via Gmclist
Sent: Saturday, April 11, 2020 7:43 AM
Ok, now that is funny, and Makes perfect sense.
I have the extended new bars. Nothing to do but try them.
Thanks
> Noticed, yes, but apparently not objectionable to all. I know people that didn't like the tendency of the drive wheels to walk sideways when
> climbing a steepish curve and took off the spacers. I've experienced the same with the one ton. Others either don't climb steepish curves or the
> sensation doesn't bother them.
> I've asked numerous people over the years how many GMCs they've driven, not just around the block but put it through its paces, and the number is
> frequently one. If you haven't driven a number of coaches I don't think you can know what normal is and how they're supposed to drive. And people
> get used to what they're driving and believe that's normal.
> Alex Ferrara, GMC Steering Whisperer, told me a story about him asking a _long _ time GMC owner and guru if he could look at the guy's steering
> while at a GMCMI Convention.
> No, no it's fine! No need.
> Humor me.
> ...okay, take a look.
> Your steering box is out 30°, let me fix it.
> Thanks, but no need, I've been driving it for 20 years and it drives fine.
> Humor me.
> ...sigh, okay, go ahead.
> {15 minutes later} Okay, take it for a drive.
> {returns 10 minutes later with a huge smile} Oh my god! All this time I thought that that was how it was supposed to drive!! Thank you!
> Richard
Columbia, SC.
Thanks Hal,
I have the bigger bars, will crawl under and see what the pork chops are. Couldn't hurt to have new, I guess.
> 40+ years of service. If you have the later version bars they should have the extended ends and 'should' work. Most of the one ton LCA's had the
> sockets strapped/strengthened and normally are OK (although I managed to blow one out) but I have quite a bit more weight up front than most. The
> adjustable PC's probably won't be necessary 'but' still may be needed. It seems there were possibly 3 different pork chops out there and it will
> depend on your particular coach combination.
> Good luck, Hal
Columbia, SC.
On Sat, Apr 11, 2020 at 7:20 AM Joe Weir via Gmclist <
> Thanks Hal,
> We have been supplying the beefy bars and can’t say that it is the
> greatest thing.
need to see why it started to sag and figure that out.
I do agree with Hal that twisting the tb more is not good, but it has
worked on several coaches we had in our dhop.
We do also supply the adjustable pork chops and get good review from owners.
The socket in the control. Arm is a major concern, you need to remove the
arm or the bar and feel the indent that is starting, as it will pop
eventually.
We sell lot of beefed up arms .😷
> > Good luck, Hal
> Coachmen
> beverage center...
> Columbia, SC.
http://www.gmcrvparts.com
There are easy way to do all this without taking everything apart.
We seldom touch the pork chop to remove the tb.
>> Thanks Hal,
>> greatest thing.
> owners.
> eventually.
>> > Good luck, Hal
>> Coachmen
>> beverage center...
>> Columbia, SC.
>> GMCnet mailing list
> Jim Kanomata
> jimk
> 1-800-752-7502
Peter Huber in California, and I in Oregon partnered up (kinda) on the
latest version of the GMC torsion bars. They can be identified by the fact
that one end has a longer "hexagon shape" than the other end does. The
spring steel that they are manufactured from differs in strength from the
original GMC bars by 19% approx.
The manufacturer wanted a minimum order to make it worthwhile for them
to even make them. That is one of the reasons Peter and I collaborated on
them.
Another was to allow folks from outside California to order them from me
instead of Peter, thus avoiding some California sales taxes.
As with most new suspension parts, like coil springs, leaf springs,
torsion bars, etc. some settling with initial use is NORMAL. That is why
the pork chops are adjustable.
Hal St. Clair has a different problem. The all-up weight of his diesel
conversion overcame the maximum point of elasticity even the new heavier
duty bars. In his case, larger diameter were needed.
Kinda like flexing a rubber band. Stay within their elastic range and
you can stretch them repeatedly for a long time. But stretch them a little
too far, and you exceed the strength of materials involved.
Spring steel behaves much the same way.
All that I am saying is "Some settling will occur upon break-in, and
this is NORMAL. Expect that you will have to re-adjust ride height after
all that new stuff breaks in.
Salem, Oregon
On Sat, Apr 11, 2020, 7:20 AM Joe Weir via Gmclist
wrote:
> Thanks Hal,
> > Good luck, Hal
> Coachmen
> beverage center...
> Columbia, SC.
> them to even make them. That is one of the reasons Peter and I collaborated
> on them.
> diesel conversion overcame the maximum point of elasticity even the new
> heavier duty bars. In his case, larger diameter were needed.
> Jim Hupy
> Salem, Oregon
> On Sat, Apr 11, 2020, 7:20 AM Joe Weir via Gmclist <
>> Thanks Hal,
>> > Good luck, Hal
>> Coachmen
>> beverage center...
>> Columbia, SC.
>> GMCnet mailing list
> Humor me.
> Humor me.
> Richard
I could use that GMC Steering Whisperer out here in CA. I had the front-end rebuilt late last year and steering is just as bad now as before it was
rebuilt. I am going to have the shop that rebuilt the front end look at the Steering Box Highpoint to ensure the box and u-joint are properly
aligned.
Ed Clerkin | 1974 GMC Canyon Lands 26’
Sometimes, not everytime, poor steering is not coming from the front end.
If the rear bogies are out of alignment, or excessively worn in the pins
and bushings, or the rear wheel bearings are sloppy, that motion under way
will be transmitted through the coach frame to that area that your butt
occupies when you are driving the coach. This motion, which you feel in the
"seat of your pants", gets translated by your brain as something that needs
correcting by moving the steering wheel. Which we all do.
Pilots call it "Flying by the seat of your pants". You can call it
"poor steering, or a failure of the coach to track correctly down the
road". Same effect.
It's really worth your time to check that rear suspension. Lots of
stuff to wear out back there.
Salem, Oregon
On Sat, Apr 11, 2020, 10:00 AM Ed Clerkin via Gmclist <
> on Fri, 10 April 2020 19:30
> > Humor me.
> fine.
> > Humor me.
> > Richard
> it was
> aligned.
Like James said. If the alignment was performed with incorrect REAR height
and castor not maximized then steering feel and stability will suffer.
Sully
Bellevue wa.
On Sat, Apr 11, 2020 at 10:57 AM James Hupy via Gmclist <
> road". Same effect.
> Jim Hupy
> Salem, Oregon
> a
> > > Humor me.
> > fine.
> > > Humor me.
> I
> > > Richard
> before
> > it was
> > aligned.
test...anybody read this test..I am reading posts but I get no response from my inquiries
From: Gmclist on behalf of Bruce Hislop via Gmclist
Sent: April 11, 2020 6:42 AM
Cc: Bruce Hislop
Subject: Re: [GMCnet] Front end sag after one-ton install?
torsion bars.
Bruce Hislop
ON Canada
tks Mr. Hupy...Brian 77 ele 455
Sent: April 11, 2020 2:49 PM
Cc: James Hupy
Brian, I see 'em.
Salem, Oregon
On Sat, Apr 11, 2020, 1:27 PM Brian Waddell via Gmclist <
> from my inquiries
> via Gmclist
> To: gmclist
> Cc: Bruce Hislop
> shorter
> torsion bars.
> Bruce Hislop
> ON Canada
