I wipe them on both sides with mobil 1 and than make a shield out of thin
plactic like milk carton and insert it thru the rear seal from the front of
the knuckle so it protects the seal from nicks when installing the axel
shaft thru it. works fine.
>The maintenance manual says to lubricate the seal lips with Special Seal
>Lubricant No. 1050169 or equivalent when installing the seal. Is the Mobile 1
>grease I'm using on the bearings okay or should I use something else?
>David
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
"The beautiful Mohawk Vally"
>David
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
