Fridge
tom geiger
673
Sorry guys, I know this subject has been beat to death but I wanted to get everyone’s input on it. I am debating about a fridge upgrade to a 2 way
propane fridge but am starting to see and read some scary stuff pertaining to fires with them. So I’be got a very dependable fridge that I was told
by the PO they had put a new high efficient cooling unit and compressor in. Considering the safety of the all electric fridge is there a better way
to maintain its running on a off grid situation. Solar panels, small quiet portable generator? It does have a healthy 6k Oman that I had a full
work over, new panel and gaskets and seals, carb rebuilt. Only had 300 hrs on it when I bought it but just time had taken its toll. Anyhow it’s
healthy.
Just to give some background on this subject matter I’ve been debating with myself on going all in on this motorhome and get it where I want it for
long trips to national parks, or just start looking for a good used diesel pusher that’s give a bit more livable space and more umph going up the
mountains and the brakes as well. Well in looking I came across some salvage RV that had some fires that did some substantial damage to the skin and
substructure of the coach around the fridge. Just got me rethinking this.
Thanks,
TG
Tom Geiger
76 Eleganza II
KCMO
An RV salvage yard will show you all the different ways an RV can burn. A visit is an education and eye opening, but it's a small subset of RV
deaths. As far as I know there are exactly zero RVs, or any vehicle for that matter, that are immune to fire, and they all have their
susceptibilities. Far more RVs die from leaks and rotted wood than from fires, but it is essential that owners are aware where fires are likely to
start and to pay extra attention to inspection and maintenance of those areas.
Propane refrigerator fires are most commonly due to lack of due diligence - frequent inspection and maintenance is mandatory. Same goes for
electrical and engine systems.
Diesel pushers can burn at the back where the motor is and where the exhaust extends up inside the rear corner. If they're lucky they only lose the
back bedroom - still enough to total a coach. I saw a nifty making-lemonade-from-lemons burned DP at Arizona RV Salvage in Phoenix. Instead of
rebuilding the rear of the bus they cut off the rear bedroom and put in a 5th wheel hitch - the combined length was about 60' or 65'.
Mac the Firefight guy gave a seminar in Quartzsite to a group of 4x4 towing DPers where he informed the group that a common cause of DP fires was a
passenger side (IIRC) front tire blowout. My thoughts at that - say what...? It seems that the front radiator's coolant lines are susceptible to a
flailing 22.5" steel belt from a blowout, and antifreeze does burn, even a 50/50 mix (water is boiled off).
There are trade-offs in everything. Propane is great for boondocking, especially in colder weather. There may be a GMCer who boondocks with electric
heat, but I don't know of any and if they do they have a lot invested in batteries and solar panels and still have to run the generator every day.
Tom, is the new compressor in your refrigerator a Danfoss? The Danfoss compressors are very efficient and used by most of the refrigerator
manufacturers, and those refrigerators are popular with boaters. Cue Matt Colie.
Richard
'77 Birchaven TZE...777;
‘76 Edgemonte
Richard, great write up. This certainly makes sense. It does relieve my mind a bit on doing a propane fridge. As far as what kind of compressor I have
I would imagine it’s not the latest and greatest because I purchased the GMC in 2000. So I would think it’s not the absolute most efficient. I
have read about routing the propane line to avoid the wheel well in case of a steel belt blowout. The other concerning part is the venting of my
fridge space. I do have a vent on the side of the coach at the fridge compartment, along with a vent at the roof above. But the vent on the side of
the compartment is above the floor by 4 inches or so. In that I think I will need to drill holes in the floor to vent out any propane from any leaks.
This is the part that kinda spooks me. I guess maybe I can see if there is a propane sniffer that can send a alarm by Bluetooth to a alarm inside the
coach as well to my phone?? Any chance of such thing?
Thanks
TG
Tom Geiger
76 Eleganza II
KCMO
One of the biggest no-no's is to think that space behind the fridge is a
neat place to cram "stuff" into. Don't even think about doing that. Keep it
cleaned and tidy back there.
On Sun, Jan 31, 2021, 8:22 AM tom geiger via Gmclist <
> have
> of
> leaks.
> the
> Thanks
> TG
> Tom Geiger
> 76 Eleganza II
> KCMO
following copied from:
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/26984973/print/t
rue.cfm
Posted By: stickdog on 05/31/13 07:34pm
As far as replacement cooling units go I replaced my Dometic unit with a
Amish built unit last year. I installed it myself, it took longer to do
than they say but we are happy with the unit.
* This post was edited 05/31/13 07:41pm by stickdog *
I had my Norcold cooling unit replaced with one of the David Force Amish
Units a bunch of years ago.
More info and pictures at:
http://aegiforensics.com/library/pdfs/Invest-Absorpt-Refrig-Fires-Part1.p
df
If fire is your concern and your Norcold fridge is running fine you may
want to consider an automatic fire extinguisher system.
Fire Fight Products
www.firefightproducts.com
Automatic Supplemental Fire Suppression solutions. SS30 - Fridge fire
protection SS30 � Clean Agent Gas, 1 lb�..Fridge fire protection ...
ron Clark
On Sun, 31 Jan 2021 07:40:05 -0700 tom geiger via Gmclist
> to get everyone�s input on it. I am debating about a fridge
> upgrade to a 2 way
> pertaining to fires with them. So I�be got a very dependable
> there a better way
> I had a full
> Anyhow it�s
> healthy.
> Just to give some background on this subject matter I�ve been
> where I want it for
> diesel pusher that�s give a bit more livable space and more umph
> going up the
> to the skin and
> this.
> Thanks,
> TG
> Tom Geiger
> 76 Eleganza II
> KCMO
Most fridges are not installed
Properly. Even at factory.
They are massive massive numbers of propane fridges that do not catch fire.
If installed properly, maintained, and any recalls dealt with. i would(and do as i have a dometic rm2652 w way fridge in my gmc) do not loose any
sleep worrying about a fridge
Fire. You can always add fire supression if you want too.
Propane fridge in my opinion is the way to go for boondocking/off grid. There are some newer all electric fridges that do well, but are twice the
cost of a 2 way absorption fridge.
Gmc will get you more places to camp because of it’s size and maneuvering. A diesel pusher will have more room inside and also climb and tow
thing better.
But I dont think finacially you can beat a gmc over a diesel pusher.
Jon Roche
75 palm beach
St. Cloud, MN
The NEW units have overcome that fire issue.
Lot of the GMC owners are storing combustals in the Refrigerator rear
compartment.
Put up an separator and keep them at least 2-3 " away from the hot spot.
On Sun, Jan 31, 2021 at 2:06 PM Jon Roche via Gmclist <
> fire.
> loose any
> and tow
> thing better.
> Jon Roche
> 75 palm beach
> St. Cloud, MN
http://www.gmcrvparts.com
I'm guilty of storing a LOT of stuff in the Dometic RM2652 compartment of
my 23': A 1-1/2hp 120vac air compressor (repackaged Sears) and coiled 25'
hose, a 3+ton bottle jack, a couple of 25' extension cords, wheel chocks,
and a couple of 4x4 blocks for shoring. Nothing highly combustible and all
separated from the back of the refer with an expanded metal "fence" by
about 3". The recessed floor of the compartment is ventilated with 3
screened 1" holes in it to prevent trapped LPG.
JWID for 20 years w/o problems.
On Mon, Feb 1, 2021 at 12:25 AM Jim Kanomata via Gmclist <
> compartment.
> > fire.
> > loose any
> the
> > and tow
> > thing better.
> > Jon Roche
> > 75 palm beach
> > St. Cloud, MN
> Jim Kanomata
> jimk
> 1-800-752-7502
I just store my water hose in there now. I guess I can try to store that somewhere else.
Good to hear the new 2 ways have resolved the fire issue. Is there make and model recommended as replacements?
Thanks
Tom
Tom Geiger
76 Eleganza II
KCMO
I really think you are over thinking this a little bit. First do NOT drill holes in the refrigerator cabinet floor. The refrigerator is technically
outside air while underneath the floor is a cabinet and inside air. With holes, if you had a leak there would be a path to dump propane inside the
coach.
I have propane a powered refrigerator and I love it. I have had both Norcold and Dometic brands and would never consider electric. If fire in the
refrigerator is bothering you place an automatic fire extinguisher in the refrigerator cabinet screwed to the floor. Jim K has some that would work
well.
Do not forget the other things in your coach, like the main engine, the onan, the gas stove and the furnace. They all have the potential of catching
fire. I would worry about the Onan and main engine followed by the furnace, stove, and finally the refrigerator. This is from someone who has had a
fire and won fighting it. In my case the main engine caught fire and caused over 10K in damage.
Ken B's right: You DON'T want to dump LPG into the coach. When I
mentioned my vent holes, I should have mentioned that my refrigerator
compartment is fiberglassed up about a foot, with a 1" high "dam" across
just behind the refer base. That dam prevents any water getting from the
almost-exposed outer portion of the compartment into the house side. It's
in that protected area that my ventilation PIPES (NOT merely holes) are
located, extending down into the wheel well. Those pipes have wads of
stainless steel wool in them to keep critters out.
On Fri, Feb 5, 2021 at 10:41 AM Ken Burton via Gmclist <
> technically
> coach.
> the
> well.
> catching
> had a
> Ken Burton - N9KB
> 76 Palm Beach
> Hebron, Indiana
As to Ken Bs post, most of the GMC fires I have seen or heard about started
in the engine bay with a fuel or electrical fire.
Sully
Bellevue wa
On Fri, Feb 5, 2021 at 7:41 AM Ken Burton via Gmclist <
> technically
> coach.
> the
> well.
> catching
> had a
> Ken Burton - N9KB
> 76 Palm Beach
> Hebron, Indiana
I have repaired fire damage in several GMC coaches. From what I have seen
personally, electrical fires in the 12 volt systems lead the list, next
comes flexible fuel lines combined with plastic see-through fuel filters,
and lastly comes transmission fluid leaks sprayed onto hot exhaust systems.
I haven't dealt with any propane fires, but I always check the compartments
for combustible materials.
Onboard fire suppression in the engine compartment, fridge
compartment, and Onan generator compartment are a very wise addition, as
well. Jim Bounds as well as Applied GMC both have very good systems for
sale.
On Fri, Feb 5, 2021, 9:14 AM Todd Sullivan via Gmclist <
> Sully
> Bellevue wa
> > technically
> > coach.
> > the
> work
> > well.
> > catching
> has
> > had a
> > Ken Burton - N9KB
> > 76 Palm Beach
> > Hebron, Indiana
Any specifics on the electrical fire issues inside the engine compartment, most common ones and recommendations to improve or upgrade to prevent?
As to transmission lines, same type of question, steel flex lines? Heat shielding/deflector?
Agree fully with fire suppression system need to be in engine compartment and generator compartment.
Thanks
Randy Hecht
Roswell, GA
1974 Canyon Lakes GMC Motor-coach
> sale.
> Salem, Oregon
>> Sully
>> Bellevue wa
>>> technically
>>> coach.
>>> the
>> work
>>> well.
>>> catching
>> has
>>> had a
>>> Ken Burton - N9KB
>>> 76 Palm Beach
>>> Hebron, Indiana
>>> GMCnet mailing list
One 12 volt fire was caused by a combination of things. The battery box
floor was rusted through, allowing the batteries to slide forward and tip
towards the ground. The second thing was that the wrong batteries were
installed in the coach by Les Shwabs in Wilsonville, Oregon. They were dual
post style batteries and the front posts were unprotected from making
contact with the front lighting harness for the headlights. The installer
used bungee cords for hold downs, that were loose enough to allow the
batteries to move around. Because all the electrical grounds are shunted
back to the common electrical ground on the coach, when the batteries made
contact with the headlight harness, a dead short occured through the
electrical harness. A melted conductor in the harness did the rest. It
destroyed the harness, the dimmer switch, both headlights, the horns, the
headlamp switch and more stuff. The coach owner grabbed the red hot harness
with his bare hands and burned the heck out of them. Took me 2 months to
find all the burned out stuff, and to make a new harness and get rid of the
fire fighting chemicals.
Sale., Oregon
On Fri, Feb 5, 2021, 9:48 AM Randy Hecht via Gmclist <
> Thanks
> Randy Hecht
> Roswell, GA
> > On Feb 5, 2021, at 12:32, James Hupy via Gmclist <
> seen
> systems.
> compartments
> > sale.
> > Jim Hupy
> > Salem, Oregon
> started
> >> Sully
> >> Bellevue wa
> >>> technically
> With
> the
> >>> coach.
> in
> >>> the
> the
> >> work
> >>> well.
> >>> catching
> >> has
> >>> had a
> >>> Ken Burton - N9KB
> >>> 76 Palm Beach
> >>> Hebron, Indiana
> >>> GMCnet mailing list
> >> GMCnet mailing list
Thanks, I for one am going to go and inspect my coach, ensure proper mounting, and may add a non-conductive shield between the batteries and any wiring just in case or an accident causes a situation. Sort of the Ford fix to the Pinto rear axle and fuel tank.
Randy Hecht
Roswell, GA
> Sale., Oregon
>> Thanks
>> Randy Hecht
>> Roswell, GA
>> seen
>> systems.
>> compartments
>>> sale.
>>> Jim Hupy
>>> Salem, Oregon
>> started
>>>> Sully
>>>> Bellevue wa
>>>>> technically
>> With
>> the
>>>>> coach.
>> in
>>>>> the
>> the
>>>> work
>>>>> well.
>>>>> catching
>>>> has
>>>>> had a
>>>>> Ken Burton - N9KB
>>>>> 76 Palm Beach
>>>>> Hebron, Indiana
>>>>> GMCnet mailing list
>>>> GMCnet mailing list
>>> GMCnet mailing list
