Fresh water tank
boybach
1,033
195
63
Hi - does the frashwater tank on a 77 Palm Beach have a drain? If it does, where is it located?
TIA
Larry
Larry - Victoria BC -
1977 Palm Beach 40,000 miles, PO said everything working but forgot the word NOT. New Atwood fridge, water heater & furnace. New SS exhaust system,
6000w Onan, Iota Converter, R134A A/C, New fuel lines & heat exchange hoses
On the lowest towards the rear.
Take the shields off and look.
> TIA
> Larry
Jim Kanomata ASE
http://www.gmcrvparts.com
Hey Jim what shields are those? and where which side?
Larry
Upholstered panels
> Larry
Jim Kanomata ASE
Passenger side.
> Upholstered panels
>> Larry
>> hoses
>> GMCnet mailing list
> Jim Kanomata ASE
> jimk
> 1-800-752-7502
Jim Kanomata ASE
On my 77 PB the drain is on the passenger side under the propane tank
access door. There is a rod you pull to open the drain to let the water
drain out.
> Passenger side.
> On Sun, Oct 24, 2021 at 7:17 PM Jim Kanomata
> > Upholstered panels
> >> Larry
> system,
> >> hoses
> >> GMCnet mailing list
> > Jim Kanomata ASE
> > jimk
> > 1-800-752-7502
> Jim Kanomata ASE
> jimk
> 1-800-752-7502
That rod was added by a prior owner. The factory installed a small. Valve in a line just along the back lower edge of the tank. If you turn the lever the tank wil drain through a fitting through the floor. Very slowly.
Emery Stora
> drain out.
>> Passenger side.
>>> Upholstered panels
>>>> Larry
>> system,
>>>> hoses
>>>> GMCnet mailing list
>>> Jim Kanomata ASE
>>> jimk
>>> 1-800-752-7502
>> Jim Kanomata ASE
>> jimk
>> 1-800-752-7502
>> GMCnet mailing list
Emory,
Glad you pointed that out.
There are lot of mods out there.
Just because it is that way on your coach, it was not factory.
On Mon, Oct 25, 2021 at 5:32 AM Emery Stora via Gmclist <
> Emery Stora
> > drain out.
> >> On Sun, Oct 24, 2021, 9:17 PM Jim Kanomata
> >> Passenger side.
> >>> Upholstered panels
> >>>> Larry
> the
> >> system,
> >>>> hoses
> >>>> GMCnet mailing list
> >>> Jim Kanomata ASE
> >>> jimk
> >>> 1-800-752-7502
> >> Jim Kanomata ASE
> >> jimk
> >> 1-800-752-7502
> >> GMCnet mailing list
Jim Kanomata ASE
Well, at least I now know where the tank is situated! -
I know it's easy to describe things when these things are familiar and second nature to veteran owners -but keep in mind I didn't even know where the
tank was until reading the above just now as this is the first winter I've had to deal with it - don't forget, I just bought the coach in March of
this year.
Larry
I replaced that valve Emery described with a 1/4 turn open to close ball valve. Then ran a rod through the side wall under the propane tank so the
valve can so can easily be transferred. For the rod I use stainless old Ford car radio antennas from the junk yard for $1.00 each.
Thanks for the info Emory, I did not know that.
Jim
On Mon, Oct 25, 2021, 7:32 AM Emery Stora via Gmclist <
> Emery Stora
> > drain out.
> >> Passenger side.
> >>> Upholstered panels
> >>>> Larry
> the
> >> system,
> >>>> hoses
> >>>> GMCnet mailing list
> >>> Jim Kanomata ASE
> >>> jimk
> >>> 1-800-752-7502
> >> Jim Kanomata ASE
> >> jimk
> >> 1-800-752-7502
> >> GMCnet mailing list
