Fresh Water Tank Vent
voyager
155
David,
My problem with the vent hose is its got mildue in it. I cant get it clean,
Don't want to remove the
wall panel...so I'm going to run a vent back to
the fill cap. I will run the hose up the wall
behind the paneling on the outside frame if
I can find a route without having to drill the
frame. Maybe up by the window. Plenty of room
between the window frame and wall frame.
Rob Teed 74 Painted Desert
( Pray for the children )
> -----Original Message-----
> From: owner-gmcmotorhome
> [mailto:owner-gmcmotorhome]On Behalf Of
> HamRealtor
> Sent: Thursday, April 22, 1999 2:15 PM
> To: GMCmotorhome
> Subject: GMC: Fresh Water Tank Vent
> My tank vent is plugged somewhere. It has the fill from the right
> side. The
> vent is connected to a hose that t's and one line goes back to
> the fill and
> the other line goes up in the area of the bathroom somewhere. I
> assume this
> is where it's plugged. Does anyone have any ideas about it and
> how to find
> the other end?
> David
Thanks for the info Justin,
I'll try what you said.
> [mailto:owner-gmcmotorhome]On Behalf Of GMC77PB
> Sent: Friday, April 23, 1999 5:15 PM
> To: gmcmotorhome
> Subject: Re: GMC: Fresh Water Tank Vent
> Rob
> A solution of 50% Clorox and 50% water WILL KILL the mildew. You
> may not be
> able to get it all the way up the vent tube, but if you can, it will take
> care of it. This same solution works on wood dry rot. In that
> case, soak it
> and let dry. No further decay.
> Justin
> PS
> Have you tried taking the medicine cabinet out for access to the
> top of the
> vent.? I had to take mine out to get to the shower hose
> connection and seems
> like the vent area was accessable. (Palm Beach) That is of course
> if you have
> the side bath.
