I made one similarly, but sealed on both ends. The low end is tapped into
the water outlet, and the upper end tapping into the fill tube. This way it
is a closed system. I patterned mine after looking at a big coffee pot with
a sight glass on the front. A heck of a lot more accurate than the old
gauge!
Tony Bad
To:
Sent: Wednesday, April 26, 2000 1:21 PM
Subject: RE: GMC: Fresh water tank leaks
> Gary,
> Thanks a million. What a marvelous idea. Why can't I think of these KISS
> solutions? I guess it's because my Rube Goldberg mind is now thinking of
> ways to cap the tube to let air in and keep the mud daubers out. I'll
hook
> one up tonight.
> Bob McL
> -----Original Message-----
> From: owner-gmcmotorhome
> [mailto
wner-gmcmotorhome]On Behalf Of Kara Kosier
> Sent: Wednesday, April 26, 2000 9:19 AM
> To: gmcmotorhome
> Subject: Re: GMC: Fresh water tank leaks
> Bob,
> Go to the hardware, get some clear plastic tubing of a size
> that will fit over the tank drain outlet under the coach and
> run it into the propane compartment, terminating it at the
> highest point you can reach. Open the tank drain valve
> and -Voila!- water seeking it's own level gives you a crude
> but failsafe water level indicator.
> Gary Kosier
> From: Bob Mclaughlin
> To:
> Sent: Tuesday, April 25, 2000 7:52 PM
> > Thanks Emery. I think I'll go with no hole. My gauge doesn't work now
> but
> > I'll be able to fill it every time I dump and know more about the
quantity
> > than I know now.
> > The capacitance type you mentioned intrigues me. Time to experiment.
> > Bob McL
> > [mailto
> > EMERYSTORA
> > Sent: Tuesday, April 25, 2000 4:24 PM
> > To: gmcmotorhome
> > about
> > making my own probe. I once had a Travco motorhome that had a small
piece
> > of
> > plastic rigid tube with a stainless steel wire running down the outside
of
> > the tube. Inside the tube were a series of resistors. The tube was
> fitted
> > into a standard plastic pipe plug with the two wires entering through
two
> > holes drilled into the plug. There was a small hole in the tube just
> below
> > the threads of the hole so that the water level could rise and fall
within
> > the tube. There were resistors at the 1/4, 1/2 and 3/4 levels. When
> empty
> > all the resistors were in series. When the water was at, say 1/2, the
> > bottom
> > two resistors were shunted bay the water and only the top resistors were
> in
> > the circuit. I would think you could make something like this quite
> easily
> > and drill and tap a small hole in the top of the tank for the plastic
pipe
> > plug. This assumes that when the tank is full the resistance of the
gauge
> > circuit is Zero and when full it is the sum of the resistors up to 90
> ohms.
> > (our GMC is a 90 ohm gauge). I have forgotten which way our GMC gauge
> works
> > but I think that full is zero and empty is 90 ohm. You'd probably have
to
> > experiment with the values of the resistors to make this work properly.
> > Another type of gauge sender could be fabricated by attaching an
aluminum
> > plate to opposite sides of the tank or on one side and then around the
> > corner
> > to the adjacent side. This would act as a capacitor and as the water
> level
> > raised it would be of higher capacitance. With the right circuit set up
> you
> > could probably make it work your existing gauge. I know that this is
done
> > with big commercial tanks but I don't have the knowledge to design the
> > circuit. If you have a friend into electronics or if you are capable, a
> > circuit could be designed to convert the capacitance readings to power
the
> > gauge.
> > I finally bought a side mounted gauge from Golby that fits into the
> standard
> > side mounted hole. It has a magnetic coupled sender circuit so that
there
> > is
> > no contact of the electronic components with the water. I cut out the
> > plastic from the gauge mounting hole and it has been in for over a year
> now
> > with no cracking of the plastic tank.
> > Emery Stora
> > 77 Kingsley
> > Santa Fe, NM
