Freeze Plugs- what do i need to know ?
I had good luck using a slide hammer with puller jaws, but I think I had more left than you do.
> I have had some leak after installation without some kind of sealer, and then had to go get another plug because removal distorts the plug. :x So
> now I use the Indian Head shellac or Permatex #2 on them to avoid that possible scenario.
Yes, that's exactly what happened. It came out easy enough with small flat punch. I sanded the hole smooth and pushed the new one in and it leaks a
bit. Not a big deal.
As i had to drop the exhaust manifold to get to it and i did not have a replacement gasket, I'll be revisiting this whole thing as soon as the new
gasket arrives.
Dave & Ellen Silva
1972 Revcon Olds 455, toro drive train. All Stock
