Scott have you got the dimensions of the frame rail , thickness, height etc
(I am at home but remember that it is just a U section right? . Maybe it is
an off the shelf steel fabrication, available from a supplier. I have access
to any kind of new or used steel. Tell me what it is and I will find out.
would be nice if we could provide them to other GMCers at low cost.
>writes:
> just a set of bent channels? My 73 has a chronic case of frame cancer
> that I'll have to deal with eventually. >>
> Well Patrick, from now on, everybody, that uses my website, I want a royalty.
> Actually Patrick, I had them done even lower than posted. I didn't want
>some of you to feel bad if you didn't come up with the same price I got. The
>$350 included some plates that I had to fabricate to also repair the boogie
>frame itself. That film is being developed and I will post that to. I would
>venture if you have rust on your frame and you can notice it, you also have a
>problem with the bogie frame too. It is just in the way they are sandwiched
>together.
> As far as drilling, no. Patrick you haven't been to my website have you?. I
>tried to explain as much as necessary in it.
>http://www.bytedesigns.com/nehoda t=_self]HEINZ NEHODAS BACK YARD[/url]
> Scott Adohen
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
>writes:
>together.
> Scott Adohen
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
