Might also make you a flat camper!
>In a message dated 5/25/99 1:42:53 PM Eastern Daylight Time,
>> I sense a problem checking for flatness.
>Hi Steven!
>I don't have any problem with the frame being flat. It is as straight and
>flat as a lazer beam. No bends or nothing. It is so strong I might even
>attempt to jack it up sometime along the edge where there isn't a crossbrace
>to see if it bends like the OEM frames will do? Mine is no longer OEM as in
>1/8", it is 3/16" but what a difference 1/16 of an inch makes. My concerns
>now relate to a method of aligning frame to coach body mounts once I get the
>frame back under the coach but still on automotive car jacks. The car jacks
>don't move in a straight up movement, they move diagonally up.
>I have pictures of how I removed it but the reverse is allittle different
>because I care alot more about destroying all the work put into it. Having
>it fall off the jacks would not make me a happy camper
http://members.aol.com/adohen/advice/index.htm
>Thank you for the thoughts,
>Scott GMC FRAME
>OFF
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
"The beautiful Mohawk Vally"
