I had a voltage drop from 13.6 to a range of 8.5 to 9.8. I followed the circuit and tested all along the way. It took me over two hours and a WHOLE
LOT of frustration. It was a ground at the disconnect and the converter. It looked good until I took it apart and found it full of corrosion. Took
it apart cleaned it up and everything is back to normal. It is a regular comment on this board to check the ground connections.
HTH
Melbo
HTH
Melbo
