Ford Azure / F-150 Eco Boost Vacuum Pumps
robert mueller
17,586
G'day,
As promised here's a revised album showing both the Ford Azure and F-150 Eco Boost Vacuum pumps.
http://www.gmcmhphotos.com/photos/g7124-ford-azure-2f-f-150-eco-boost-vacuum-pump.html
Feel free to ask questions.
I spoke to Dave Lenzi and he's still selling his kit; please contact him directly for info on the kit:
http://www.gmcmotorhomemarketplace.com/lenzi/index.html
The Pedantic Mechanic
Sydney, Australia
G'day,
Additional info on the F-150 Eco Boost Pump:
RockAuto P/N: MOTORCRAFT BRPV30
Link: https://www.rockauto.com/en/parts/motorcraft,BRPV30,vacuum+pump,5172
McMaster-Carr Rubber isolator mounts:
https://www.mcmaster.com/#rubber-isolators/=1alwgb6
I used a metric size for the metal Azure pump and don't remember the size, sorry.
You'll have to tap the plastic pump screw holes to install rubber isolators therefore you'll have figger out what size to use after
you tap them.
Sydney, Australia
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Rob Mueller
Sent: Friday, December 8, 2017 9:58 PM
Subject: [GMCnet] Ford Azure / F-150 Eco Boost Vacuum Pumps
G'day,
Sydney, Australia
Speaking of promises
You were going to come visit us at mannys , now I hear this will not happen
> G'day,
> sorry.
> you tap them.
> Regards,
> Rob M.
> Sydney, Australia
> Mueller
> To: gmclist
> G'day,
> Regards,
> Rob M.
> Sydney, Australia
Alternator Protection Cable
Gene,
Yes, I had to cancel my visit because I ran out of time working on the Kingsley.
However, John Sharpe and I are planning on visiting Manny's next spring after the Tucson GMCMI / GMCWS convention.
Sydney, Australia
From: Gmclist [mailto:gmclist-bounces] On Behalf Of gene Fisher
Sent: Saturday, December 9, 2017 8:25 AM
Subject: Re: [GMCnet] Ford Azure / F-150 Eco Boost Vacuum Pumps
> Gene,
> Kingsley.
> Sure
> Regards,
> Rob M.
> Sydney, Australia
> Fisher
> To: gmclist
Here are the metric isolators I used for the pump;
https://www.amazon.com/gp/product/B00F7E9YYC/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
Hal
> G'day,
> you tap them.
> Regards,
> Rob M.
> Sydney, Australia
> To: gmclist
> G'day,
> Regards,
> Rob M.
> Sydney, Australia
1977 Royale 101348,
1975 Eleganza II, 101230,
Rio Rancho, NM
Hal,
To install the metal Azure pump I used isolators that had metric studs one end to screw into the pump and threaded sockets on the other for metric screws.
It should be noted that if you purchase the F-150 version you will have to thread the holes that the "plastic screws" go into. Would suggest you use an isolator with coarse threads if available.
Sydney, Australia
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Hal StClair
Sent: Sunday, December 10, 2017 12:18 AM
Hal
