Hey Mac, on the subject of other people's opinions, there are a whole bunch
of ways this can go. We are dealing with people here. If I have learned
anything from being married to my first wife for 50 years, and still
married to Judy, it is that people's preferences differ. What works for one
couple, might not work for another. That was my point, and it was not
intended to be criticism. Sorry if it was taken that way.
My wife is proud to be my wife as I am proud to be her husband.
Some people are simply too danged touchy!
D C "Mac" Macdonald
Amateur Radio K2GKK
Since 30 November '53
USAF and FAA, Retired
Member GMCMI & Classics
Oklahoma City, OK
"The Money Pit"
TZE166V101966
'76 ex-Palm Beach
k2gkk + hotmail dot com
jamesh1296>
Sent: Tuesday, March 6, 2018 17:24
Subject: Re: [GMCnet] Floor not level
Some wives might take exception to being referred to as some man's
possession, like, my car, my toothbrush, my wife, etc. Some may actually
prefer to be known as THE WIFE. Kind of a case by case deal. I would tread
lightly around that subject. Machines are far simpler to figure out than
wives are, jus sayin'. (Grin)
Salem, Or
78 GMC ROYALE 403
Don't know you from Adam and I don't know where you live, but I commend you
for your respect of the Fairer Sex.
You said, " my wife " not "THE wife" which usually sends me to the coach
for the night!
Mike in NS
On Tue, Mar 6, 2018 at 7:02 PM, John Phillips
wrote:
> And I thought about storing a ramp, like a Uhaul truck, under the coach so
> I push my wife up into the coach. If dragging is a problem then a ramp or
a
> chairlift is out of the question.
> > > Shane,
> > > I think you're going to find that the bowing of the floor is a common
> > GMCMH problem which most of us either don't notice or choose to ignore.
> If
> > > you study the construction of the body, you'll find that the basic
body
> > structure is a cage of vertical "hoops" (really inverted "U"s) anchored
> > > (welded) together with three horizontal longitudinal members on each
> > side. That cage is overlaid, and tremendously strengthened, by the
> aluminum
> > > and SMC (Sheet Molded Composite) sheets bonded to it.
> > > That basic body rests on lateral aluminum "floor joists" which are
> > welded to the lower of those longitudinal members on each side. Those
> > "floor
> > > joists" are then supported a few inches (12 or so?), toward the middle
> > of the coach, by the steel chassis, which is eventually bearing the
> entire
> > > weight of the body. Since that entire "cage" and all the cabinets,
> wall
> > finishes, etc., are thus cantilevered from the chassis with those
> > > aluminum floor joists, they eventually sag -- and the plywood floor
> > follows.
> > > Thus the only way to correct that bowing is to straighten, and,
> > probably, reinforce, those floor joists. Worth it, unless you're doing
a
> > > complete
> > > frame-off restoration? Probably not, IMHO.
> > > HTH,
> > > Ken H.
> > There may be times that I do not completely agree with Ken (either one)
> > but this is not one of those times.
> > the floor sag is (I think) more pronounced in my 73 as they had a
thinner
> > floor, so I studied the issue at some length and came to that very same
> > conclusion. The impediment to a repair is that there is no depth of the
> > frame channel to work with, so there is no place to put a diagonal brace
> to
> > the cage frame edge.
> > I even went so far as to analyze and model what could be done. If you
> are
> > willing to give 2" of ground clearance for a few new thwartships
members,
> > it could make a difference. My coach drags enough as it is, thank you.
> > Matt
> > Matt & Mary Colie - '73 Glacier 23 - Members GMCMI, GMCGL, GMCES
> > Electronically Controlled Quiet Engine Cooling Fan
> > OE Rear Drum Brakes with Applied Control Arms
> > SE Michigan - Twixt A2 and Detroit
https://nam04.safelinks.protection.outlook.com/?url=
http%3A%2F%2
Flist.gmcnet.org%2Fmailman%2Flistinfo%2Fgmclist_list.gmcnet.org&
data=02%7C01%7C%7C252b923a96c243e3b98808d583b98e93%
7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636559755335541484&sdata=
oLsgbVKd0Zv51V1Ut1vNSJFF0k3EywePiVvEjjVyG30%3D&reserved=0
> *John Phillips*
http%3A%2F%2
Michael Beaton
1977 Kingsley 26-11
1977 Eleganza II 26-3
Antigonish, NS
http%3A%2F%2
http%3A%2F%2
