Good on ya, Emery, looks like it might be a ground problem.
Now, all I have to do is find out where the ground points are for the
coach.
I didn't think it would be a voltage drop across a bad ground conection,
because LEDs draw so little current. the only 12v things that don't work
in the coach are the floor lights and the furnace, and that's turned off.
ron
On Mon, 24 Sep 2018 18:50:11 -0500 Emery Stora via Gmclist
> Still check the grounds or put a smaller resistor in the circuits.
> Emery Stora
> > LED lights, Emery, hard wired, no sockets. Good advice, otherwise.
> > ron
> > On Mon, 24 Sep 2018 18:08:32 -0500 Emery Stora via Gmclist
> >> Check the grounds from the lights and try cleaning the inside of
> the
> >> bulb contacts. Probably a corrosion problem.
> >> Emery Stora
> >>> Anybody know how the floor light wiring is routed from the
> switch
> >> by the
> >>> door in a 1978 Eleganza??
> >>> I have very dim LED floor lights, and they only have about 6
> volts
> >> at the
> >>> lights.
> >>> There is about 12 v at the switch.
> >>> Thanks, RonC
> >>> _______________________________________________
> >>> GMCnet mailing list
> >>> Unsubscribe or Change List Options:
> >> GMCnet mailing list
