So, here is what I found on the crank, I had to remove the pan and the oil as well as the crank as it needed to get balanced with the late model off
hole location flexplate. reason for some reason in my 1972 455 block there is installed a 1968 -1969 odd ball nodular iron crankshaft that was only
made for two years. Isn't that just my luck. so odd ball crack in a 1972 455 block, and now balanced with a flex plate with two hole drilled oversized
as the only flex plate available for this crank is a sfi racing flexplate that is $350.00
1" wide.
397363 455 '68 - '70 Nodular iron. 'N' on front weight
so word to the wise not everything is what is should be and yes for some reason there are some engines out there that have mis matched parts.
so another $400.00 added to the engine build as it has to balance between the flexplate crank and balancer. $10,000 and climbing and no end to the
bleeding. one of these days ill be able to drive my coach again.
1974 GMC Sequoia 26'
1" wide.
