> Larry,
> You said you have a Palm Beach, that means GM assembled. If it hasn't been to badly modified, then the house fuses are all in that electrical
> cabinet in the passage. If that is where they are, them that is also a distribution point for the house power. The converter is right there too.
> Easy thing to would be to tie the little solar to the output of the converter. Then you know you are in the right place and have both sides
> connected.
Yes Matt, the electrical cabinet is pretty much bog standard and the converter is there too. Hate to be a dullard but when you say "tie the little
solar to the output of the converter" do you mean just hook up the panel to the output connectors on the converter without any kind of controller in
between? Wouldn't that bypass any regulation? Reason I ask is, I've spent the last 4 hours looking at solar controllers and weighing the options - not
necessarily for the tiny panel you suggest but thinking maybe I'd use larger panels down the road.
I found the Flexcharge NC25A-12 to be a candidate after looking at it's granular abilities regarding AGM's. I might pick one of these up unless anyone
has had bad experiences with it?
> You got Lifeline GPL-6s for 125C$??
> Well, these days you have to wear a mask, but did you have a gun too???
> Matt
Let's just say I was lucky
- oh - and I was involved in the antique trade in an earlier incarnation :lol:
Larry
Larry - Victoria BC -
1977 ex-Palm Beach "Ol' Leaky" 40,000 miles, PO said everything working but forgot the word NOT. Atwood helium fridge, water heater & furnace. SS
exhaust system, Onan, Iota Converter, R134A, New fuel lines & heat exchange hoses
