>In a message dated 6/25/00 11:58:48 AM US Eastern Standard Time,
> I recall reading that article but I think if I sense there is an engine
> fire I will grab my sweetie, (who carries my credit card) the Registry,
> my cell phone and bolt for the door!
Well, like everything else there is more than one side to every
issue. About 3 years ago I was on a trip, more than a thousand miles
from home, when I was in a shopping center parking lot. I started
the engine and immediately got a backfire and the engine died. I
tried to start it again and then noticed a wisp of smoke from the
corner of the engine cover. I ran back and took my dry chemical fire
extinguisher from the wall by the refrigerator and then opened the
engine cover with one hand and had the extinguisher in the other
hand. There were flames about 1 foot high and I quickly put them
out. The backfire had blown out the gasket under the air cleaner and
sprayed gasoline back onto the distributor. The engine cover was
charred on the bottom, the distributor cap, rotor, coil, module,
pickup coil, plug wires, vacuum hoses, speedometer cable, cruise
control bellows and several electrical wires were burned.
Fortunately, I had a toad and scrounged up most of the parts the next
day except for the speedometer cable and cruise bellows. I was able
to replace the parts and get on the road within 24 hours for the rest
of the 4 week vacation we had planned.
Now, I realize that there is a risk in doing this but my alternative
of just bolting out the door would most likely have meant a total
loss of my GMC and its contents and our being stranded over 1000
miles from home.
If the engine is not running and the key is off there will be no more
gasoline pumping. Whatever is on the engine top will, of course
burn, and can create quite a fire. I believe that if this happened
again I would do the same thing but only if I have a fire
extinguisher in hand.
I am considering some sort of fire suppression system but meanwhile I
now have 2 fire extinguishers in the GMC. One by the base of the
drivers seat and the other mounted on the wall above the refrigerator.
Emery Stora
77 Kingsley
Santa Fe, NM
miles from home.
Emery Stora
77 Kingsley
Santa Fe, NM
