Justin,
I can't speak for others, but I enjoy most anything coming across this
forum with technical content.
If you don't get comment about a technical post, it might be because your
logic is so flawless even the quibblers can't find anything to quibble with
and you answered all the questions anyone might have.
I made note of your post, a couple by Marcus, and several others including
that sensational uproar brought about by the purchase of a Halon
extinguisher awhile back.
Twenty five years ago I had a carburetor fire in an almost new car. Maybe I
was just unlucky, but they will have a hard time convincing me it rarely
happens to well maintained vehicles. Your vehicle can be well maintained
when you leave your driveway and not so well maintained by the time you get
to the post office.
Anyway, I was on a large parking lot and several good old boys came running
with extinguishers. My sons ran into a nearby store. They and the manager
came out with several more extinguishers. It was incredible how much dry
chemical it took to finally control it.
I want to do all I can to keep our GMCMH from burning up. I think
prevention is far better than cure so I am taking a number of steps aimed
toward preventing a fire from ever starting. I think I have the prevention
part pretty well worked out.
In case a fire does start, a built in system such as yours would be a
wonderful investment.
I have been thinking about getting my fresh water system into the act. It
would seem misting or spraying 35 gallons of water onto an engine would be a
move in the right direction.
Did Arch or someone already mention doing this ?
Perhaps a chemical such as Fyrfighter could be mixed with the water down
line from the pump ?
Anyone know if water works OK when applied simultaneous with CO2, Halon, dry
chemical, or whatever else you might care to spread on the flames ?
Glenn suggests temperature warning sensors above the engine. Allied catalog
lists thermal switches that close at different temperatures. Any one know
typical and maximum under hood temperatures for a GMCMH ?
It seems motor home fires are happening too frequently to be ignored.
Don Miller
75 Glennbrook
Shenandoah Valley of Virginia
>Heinz, you know I have an engine compartment fire extinguisher system which
I
>can activate from inside. I posted about it quite some time ago but no one
>seemed to be interested. I had it designed by a friend who was in the
>sprinkler and fire extinguisher business. I have a 5 lb co2 bottle mounted
>behind the left front wheel well liner. I ran metal 1/2 inch lines from it
up
>to the underside of the floor. I have one sprinkler head on each side of
the
>opening. One is aimed at the carbureator and left side of engine, and the
>other to take care of the right side in case of oil line leak/fire. I have
a
>control inside to pull and it releases the whole extinguisher contents. I
feel
>confident it will work because a couple years ago the pin I was using
was
>made of metal that was too soft and it broke, letting it go off. My
reaction
>was that I had a bad puncture from the hissing noise. I stopped and dirt
was
>blowing up all around the front of the coach from the ground. It had that
>much pressure.My friend steered me away from Halon because of price and
future
>availability. CO2 does the job and doesn't leave a mess.
>Justin
to the post office.
Don Miller
75 Glennbrook
I
up
the
a
feel
was
reaction
was
future
>Justin
