Hey folks - it's done!
(well almost - I deferred replacing the section of plywood going into the
propane area until this fall. The propane tank is mounted with bolts
through the frame so that's not a problem. And I've sealed the propane
enclosure from the interior so that's not a problem either)
The job took 12 hours and some fussing around, but I'm satisfied with the
patch. If you want to see the whole process, take a look at
www.henry-davis.com/GMC/RearFloor.htm (you can also get there from the GMC
directory as usual)
Does anybody know of a source for the aluminum poprivets that go throught
the flooring? I'd like to put the 3 rivets into the floor.
Henry
(now I can get back to updating the permanent rear bed which was the whole
point of this exercise at the beginning of the week.)
Soquel, Ca 95073 / IP reviews
fax: (831) 462-5198
directory as usual)
Henry
fax: (831) 462-5198
