Hi GMCers:
I'm in the process of doing some more things to the "new toy" and I need
some info about the rear air suspension system. In particular, I'm going to
solve the slow air leak problem and would like to put "Prestolock" air
fittings on all places where connections are made. Hope that will solve the
problem!
I found a source for the fittings here in NJ and wondered if anyone could
anyone provide a list of the number and type of fittings used in a typical
setup before I dig around finding and counting all the air fittings? Looking
at the air tank, it appears that those fittings are 1/4" male on one end and
the 1/4" O.D. plastic tubing on the other. Is that correct? I've already
gotten the shut-off valves for the air bags and will install them at the
same time as I fix the leaks.
Any suggestions or hints will be appreciated.
Happy motoring.
Ralph Edelbach
problem!
Happy motoring.
Ralph Edelbach
