Ok folks, the dead GMC saga continues.
Went to NC to pick up the coach from Blue Ridge Machine Shop. Hersa,
the owner is a very nice, soft spoken southerner. Needless to say I
have been anxious to get the GMC back with the rebuild. He put all the
good stuff in - forged pistons, SS valves, Wolverine cam kit, High
volume Melling pump, ARP bolts & studs, copper exhaust gasket plus other
stuff I will write about later. He also installed the following parts I
furnished him - Caspro power drive, the Mondello torque converter, new
degreed harmonic balancer. Had block line bored and gone through and
did heads. Total installed cost of $2,700 to remove rebuild and
reinstall. I think a very good price.
On to the problem. Picked it up and drove it about 75 to 100 miles and
checked for leaks. It ran like a champ, lots of power and good
acceleration. No leaks found and time to hit the road to get home - a
740 mile trip. On the way home it was drinking 1/2 quart of oil every
300 miles. No smoke out tail pipe as confirmed by some friendly
truckers on the way. Opened it up today and found oil on passenger side
rear most plug. I have "Kool Sox" on the plugs and wires and this one
was soaked. In the valley where the plug goes there was a puddle of oil
and along the lower portion of the block and transmission it was covered
in oil. I have not removed the plug yet, the oil could not be coming
out of the cylinder as far as I know. The wires to the starter are
soaked and the general area is wet with oil. So there is a leak on the
rear passenger side of the block.
The only place I can determin is where the oil filter attaches to the
block. Perhaps he did not get a good seal or the oil filter has a
leak? The oil lines are dry and there is nothing in front of the oil
filter. OK Zak, Tom, Jim and others - do you think this is it or should
I look somewhere else? Pictures are available if you would like to see
them.
Hersa siad he would refund what ever it took to repair, and if it did
happen to be that it was burning oil he would do a nother engine and
swap it when I brought him the coach.
Marcus
them.
Marcus
