final drive
johnny
8,287
9
3
For the gurus - JimK especially. Would it be possible to either turn the final drive upside down, or flip the ring gear from side to side? Either
would allow a regular turning transmission to be chain driven, therefore giving some choices to the transmission used. I used to do this with VW
transaxles when they were changed from a bus to a bug or vice versa.
Johnny,
The THM425 IS a "regular" transmission, ie a THM400, as used in millions of larger GM vehicles from mid '60s to the '80s. The only significant
difference is the chain drive, and the 2 overrunning clutches which are installed "backward" when the tranny is assembled. Yes it turns "backwards",
but so would any transmission driven by a chain off a normal clockwise-rotating engine. (Extra credit: What are the two cars whose engines turned
counter-clockwise? Hint, they both begin, or began, with a "C" and I owned one of each. ;) )
Flipping the ring gear is done in a VW when you install one of those engines. In a GMC, it would only be necessary if you installed a conventional
engine mounted backward back near the dinette.
HTH
Merry Christmas and Happy Solstice to all!
Rick Staples
I have built a bunch of Dune buggies. With VW engines, when you make a mid
engine configuration, the ring gear needs to be flipped over inside the
case. I usually included a "beef-a-diff" carrier when I did this, along
with a 1-1 top gear to replace the .890 -1 top gear, along with 1st and
second gears that made it a close ratio gear set. Then, when you built the
air cooled engine up to about 175-200 hp, you had enough beans to make the
thing fly.
If the VW engine was replaced with a Corvair engine, the ring gear
swap was required, as the Corvair turns the opposite direction from the VW.
The VW transaxle is none too strong with tall final drive gears or huge
paddle tires that load the transaxle up. They will live with up to 200 hp,
but not much more than that. But, the sand usually destroys the engine
before the transaxle gives up the ghost. You want to go fast, you have to
pay the cost. Speed costs money, how fast can you afford to go?
On Fri, Dec 25, 2020, 7:09 PM Richard H Staples via Gmclist <
> Johnny,
> "backwards",
> engines turned
> conventional
> HTH
> Rick Staples
pre-2000 Honda 4-cylinder engines
rear-mounted Chevrolet Corvair engine from the 1960s
Voisin and Citroen front-wheel drive French car engines from the 1920s and 1930s.
Wasn't t6hinking it through. You'd need to gear drive it so it turns correctly and then reverse the differential. It may well be though, the
transmissions now are too long to do this withpout surgery to the steps and such.
