So I was under my coach this morning, and I noticed that when pushing on the driver's side inner axle stub where it goes into the final drive, there
was a good amt of play when pushing up and down.... I'd say it's a good 1/8" of movement.... I know some play in axle stubs is normal, but what would
be the limit where I should start to worry? FWIW, the seal axle seal is tight.... I would assume with excess play the seal would wear rapidly and I
would see some diff fluid leaking out.... Also, I don't notice any noise or anything coming from the drivetrain... The previous owner told be the
coach has the 3.42 final drive, I believe from Cinnabar, so I don't believe it is original, either.
We're thinking about taking a long trip this weekend, so of course I'm a little worried that this may be something to be concerned about.
Mark S. '73 Painted Desert,
Manny 1 Ton Front End,
Howell Injection,
Fort Worth, TX
Howell Injection,
Fort Worth, TX
