Final Drive question
Beach Coach
46
Today I removed the final drive cover to change the gear oil and to install the Ragusa final drive cover. After you remove the final drive cover; how
do you determine the final drive ratio?
Thanks,
Hugh MacDougall
MacDougall
Antigonish, Nova Scotia
1975 Eleganza II, 1977 Transmode
Count the teeth on the ring gear and call me so I can look it up for you.
> cover; how
> Thanks,
> Hugh MacDougall
> MacDougall
Applied/GMC, Fremont,CA
http://www.appliedgmc.com
To Jim K.and all, some final drives in some vehicles have the tooth count for the ring gear
and the pinion stamped on the outer part of the ring gear and somewhere (maybe the pinion shaft)
of the pinion gear, as it's maybe possible that some ratios may have the same pinion gear count as
as different ratio, but the gears must be used in sets as the gears can actually have different size teeth
but the same count. ( So I'm told.) Nissan(Datsun) Z cars and 510's 610's etc are examples I know of.
Do GMC Motorhomes have the tooth count stamped, engraved or whatever somewhere on the gears?
Thanks in advance
DAVE KING
lurker, wannabe
Toronto, Ontario, Canada
They do on factory gearsets, not always on aftermarket stuff.
> for the ring gear
> Thanks in advance
> DAVE KING
> lurker, wannabe
# of pinion teeth\# of ring teeth=ratio.
--johnny
Braselton, Ga.
"Sometimes I wonder what tomorrow's gonna bring when I think about my dirty life and times" --Warren Zevon
> # of ring teeth / # of pinion teeth = ratio.
> --johnny
There, fixed it for you
Chris Geils - Twin Cities
1978 26' Kingsley w/ very few mods; Headers, Progressive Dynamics 9040, aux trans cooler, one repaint in stock colors, R134a, Al rad, 49k mi
And may it be the only time you want “LSD” (Limited Slip Differential)…..
Dolph
DE N8JPC
Wheeling, West Virginia
1977 26’ ex-PalmBeach
1-Ton, Sullybilt Bags, Reaction Arms, 3.70 LSD, Manny Transmission, EV-6010
>> --johnny
It wasn't broken:)
--johnny
Braselton, Ga.
