Larry,
I had a 3.55 final drive installed at Buskirks Oct. of last year. There
2 guys removed the old one and put in the new one in an hour and a half.
Total shop charges 3 hrs labor. They had the special lineup tools and
jack setup. The half shafts need to be pushed to the side after being
loosen from the final. There is a bolt that holds the short shaft on
the drivers side tight. Don't forget to put it back in or your short
shaft will come loose and damage the final drive. My suggestion would
be to call Max Pardy at Buskirks and talk to him. He may be able to
suggest someone close to you that could do the job. (1-800-715-1133) If
your close to Memphis Tenn. Danny Dunn @ Dunn's Transmission builds,
sells and installs GMC transmissions and has the knowledge and
experience on the final drive. His number is 901-734-3866.
J.R. Wright
GMC Greatlaker
Michigan
> I am on the verge of upgrading my final drive. What, roughly speaking, is
> involved with installing the "bolt-in" complete units. Several RV mechanics I
> talked to today have, sort of, "begged off". Cinnabar parts lady says I need
> a final drive to transmission gasket. I gues I thought this thing went in
> from the front????? Since I now am fairly intimate with my knuckles and front
> bearings, do these have to be pulled? Cinnabar does this installation in 3
> hours of shop time. Can anybody give me the nickel tour of this installation?
> (While I'm waiting for your response, I will check my shop manual). What
> giffs, inspectok? Larry in MO, PB 75
J.R. Wright
GMC Greatlaker
Michigan
