Nate
The check of a GMC alternator is very simple since everything is
contained within the Alternator Housing. First pull the two wire
connector off the generator & verify that +12v dc is present at each
connector pin (cable side) with the Ignition On. Clean the contacts &
reinstall two pin connector. Now start the engine, any way that you can
& measure the DC Voltage present at the center terminal of the Battery
Isolator. There should be about 15 volts present if the alternator is
functional. Shut off the engine & the + 12 v DC should go to near zero
with a small test lite on the same center terminal. That's all there is
to it. If suspect faulty Alternator, take it to a Alternator Repair shop
(not a auto parts house) & have it tested & repaired. I find that the
rebuilt 80 amp alternator for a 75 Olds Toronado available at Pep Boys is
a reliable unit. If you go with a high output unit (ie 125 amps) then
the entire charging system wiring requires major work to prevent a fire
hazard condition. The existing wiring is marginal, at best, for the 80
amp OEM Configuration. 80 amps is a lot of power....why would you want
more ????
Duane of Orange CA
more ????
Duane of Orange CA
