Fancy Fire Extingushers
blank
1,525
Mark,
That's exactly how some of the new water mist fire extinguishing systems
used in marine engine compartments work. Unfortunately, they also require
extremely high pressure(~300psig usually provided by an N2 bottle and
regulator). There are some "low pressure" nozzles available, but they still
need at least 75psig.
Still lookin' tho'.
Patrick
> How about a couple of standard spray nozzles hooked up to a
> temp sensor and a twelve volt valve and the GMC's water
> tank. When the temp sensor is tripped it'll open the valve
> and turn on the water pump. 40 gallons later, no fire.
I think the idea stinks. Yuk Yuk
>Date: Wed, 28 Jun 2000 23:05:19 EDT
>From: Stammon
>Subject: GMC: A Hot Time
In a message dated 6/28/00 5:43:39 PM US Eastern Standard
Tom that's a great idea, especially if we raise up the
engine cover to
see if
it works.
MA
Alan Bredbury
Clinton, Ct.
1974 GMC 26' Classic Motorhome
http://www.finesttool.com/index.html/special.htm
Do You Yahoo!?
Get Yahoo! Mail - Free email you can access from anywhere!
http://mail.yahoo.com/
