Jim, you are making my argument. You just explained what’s wrong with the
stock setup.
But I don’t give Hayden a pass. They accepted that low quality. Not all
offshore factories turn out low quality, but they will if the buyer accepts
it.
Hayden clutches, though, were the objects of complaint here for as long as
I remember.
Rick “designs that can’t or won’t be manufactured properly or affordably
are ripe for updating” Denney
On Fri, Sep 20, 2019 at 8:30 AM James Hupy via Gmclist <
> We have been over this so many times, I have lost count. I KNOW WHAT THE
> DIFFERENCE IS. So do many of you out there in gmcnet land. When the viscous
> clutch manufacturing went "OFF-SHORE", The state of quality control went
> into the toilet. Same with alternators, mechanical fuel pumps, water pumps,
> and you name it.
> Hayden, an OLD LINE USA manufacturer of fan clutches, had to make some
> hard business decisions. Namely, adapt to the NEW WORLD ORDER and go
> off-shore, or become another Sears, K-Mart, etc. They went off-shore and
> their quality control ceased to exist, but their business offices and
> advertising continued to flourish. Lots of highly skilled U.S.A. employees
> went searching for new jobs, thanks to global economy. Love it or hate it,
> it is the NEW REALITY in replacement parts for obsolete vehicles. Not only
> GMC motorhomes were affected. The list is too large for this venue.
> So when you indicate that I don't know the differences in how these old
> girls are cooled, remember this, I have been working on GM vehicles since
> the 1950's, I've been there and back, several times.
> It sucks, but it is the reality of the times we live in today.
> Salem, Oregon
> On Fri, Sep 20, 2019, 4:51 AM Richard Denney via Gmclist <
> > I’ve heard this a lot, but it does not fit my experience. My engine temps
> > (measured coolant temps using a good mechanical temp gauge) will rise
> even
> > when on the highway, if I’m climbing or it’s a hot day. When the clutch
> > engages, the temperature is usually in the 190-200 vicinity, and with the
> > fan being driven, it will drop to 180 or a bit less (where the thermostat
> > closes) in around 20 seconds. The driven fan is highly effective at
> > lowering coolant temperatures—ram air is not.
> > I recall several extended threads years ago about why this would be. My
> > air-flow path is stock, my radiator is an aluminum Griffin, and the
> cooling
> > system is tip-top. A new engine and transmission did not change the
> > behavior.
> > So, I am persuaded that we need a functioning fan clutch even at highway
> > speed.
> > I do think my clutch is slowly degrading. The engine temperature being
> > displayed when it engages is about 10-15 degrees lower that if used to
> be.
> > I used to see temps in the 210 vicinity when the clutch engaged. If I
> had a
> > 195-degree thermostat, I don’t know how it would behave, but I think it
> > would be a fight to the death (of the clutch).
> > The electric clutch seems like an excellent way to gain some control over
> > this process. But I’ve spent all my play money this year on making it
> roll
> > straight and stop better.
> > Rick “thinking’s next year’s project may be the fan and maybe a new
> exhaust
> > system” Denney
> > On Fri, Sep 20, 2019 at 2:58 AM John Phillips via Gmclist <
> > > Jim Hupy "what is wrong with the stock fan clutch?"
> > > Just if the clutch is or becomes hard to get. I am not sure how
> effective
> > > the clutch is at cutting out when it is not needed and turning on when
> it
> > > is. It senses air temperature on the hot side of the radiator where an
> > > electric fan could sense return water temperature. I would think that
> at
> > > highway speeds even when the air is hot comming through the radiator
> that
> > > you would not need the fan on.
> > '73 X-Glacier 230 "Jaws"
> > Northern Virginia
> > Offlist email: rick at rickdenney dot com
Northern Virginia
