fan clutch
Wasn't this procedure modified to leave the A/C off? Seems I remember a
problem with overpressurizing the A/C system.
Patrick
> The procedure says to block the radiator with cardboard,
> turn on the A/Cand run the engine at (I've forgotten
> for sure) about 1500 to 2000 rpm and measure at what
> temp. the fan cuts in. You'll know that by a change in
> sound. If it doesn't cut in then you have a bad clutch.
On Mon, 06 Mar 2000 17:52:01 -0800 "chris izzig"
writes:
> how can you tell if the fan clutch is working? when i turn it by hand
> it spins about once around.
> thanx chris 75gb
If you don't hear the fan "Roar" when you start the engine it ain't
workin'!
David Lee Greenberg
The GMC Motorhome Registry
Dedicated To The Classic GMC Motorhome
www.gmcss.com/registry.htm
By all means when you block the air flow through the radiator, do not
perform the test with the A/C. The manual intructs you to turn it on but I
learned last summer that will lead to high freon pressures and blow outs.
Very costly lesson.
Phil Stewart
'76 Transmode, TN
> Patrick
