>Date: Fri, 08 Jan 1999 19:39:30
>To: gmcmotorhome
>From: "Thomas G. Warner"
>Subject: RE: GMC: Fact or fiction you decide in Coatings for exhaust=
headers
>Lets look at the facts paul. I stand by my previous information, there
appears to be no comparison between Jethot, HPC, and Swain Tech when it
comes to keeping heat transfer into the engine compartment to a minimum.
Isn't that our problem hot engine compartments? HPC says that they are "more
concerned about improving the life of your exhaust components", while jethot
says "will lower under-hood temperatures by 30=B0F or more", note that is
30degrees not percent. Swain tech says "It reduces radient heat by more than
50%. (It is NOT Hi-Temp paint like other products.)"
>=20
>I am not interested in how the headers look (who is going to see them
except road kill) and me when I am under the hood. HPC and JETHOT are
virtually the same technology and almost 20 years old at that. Jethot and
HPC are principally trying to stop corrosion and heat fatigue and thermal
transfer is only a byproduct, and appears to be minor from their web sites.
That is the reason that so many street rodders use them...looks and last a
long time.
>Go to the various web sites that I have sited and compare their claims. I
am sold on the process and want to see the factory. How about coating our
intake manifolds, pistons and final drive gears(low friction materials)=
also?
>HPC:http://www.hpcoatings.com/hpcauto.html
>HPC has been providing its services to more professional racing teams world
wide than all other coating companies combined! We have proven our worth at
Daytona, Indy and Lemans. Performance gains are in the 1-3% range, however
these gains are proportional to the engine output. For example a 1200
horsepower Pro Stock engine will see a 10-13 horsepower gain where as a
street engine will only see 1-5 horsepower. Underhood temperatures will drop
from 20-35% depending on the vehicle and airflow surrounding the engine. We
are more concerned with improving the life of your exhaust components. As
you can see HPC offers a multitude of coatings. Unlike other companies that
offer only one or two coatings, HPC offers over 40!!!=20
>BENEFITS OF HPC EXHAUST SYSTEM COATINGS:
>Superior corrosion protection (self-sacrificial quality will not allow
corrosion to develop even when damaged).=20
>Lifetime guarantee against subsurface rust and corrosion.=20
>Performance gains (increases gas velocity, improves laminar air flow, and
reduces ambient underhood temperature).=20
>Rapid cool-down.=20
>Weldability.=20
>Color availability.=20
>Will not blue or stain.=20
>Elimination of thermal fatigue/oxidation.=20
>Excellent abrasion resistance.=20
>Protection at temperatures of -375 degrees to +1,300 degrees Fahrenheit.=20
>Can be applied to both new and used components.=20
>JETHOT: http://206.243.32.11/jethot/pg3.html
>Famous for its double coatings inside and out, JET-HOT won't discolor,
crack, chip, peel, fade or burn off up to 1300=B0F making it ideal for parts
that see a lot of abuse. The latest addition to our line of coatings, JET
HOT 2000TM, even protects metals at temperatures exceeding 2000=B0F. In
accelerated salt-spray tests, JET-HOT outlasts chrome by a factor of 14 to 1
and puts other ceramics on the market to shame. In Fact, new exaust
components coated inside and out receive a lifetime warranty against
rust-through. Of course the special process that assures complete coating on
the inside of the part goes a long way toward making it last. And if the
parts you have are used, JET-HOT even goes the extra mile to strip any old
paint or rust off completely down to bare metal at no extra charge! The
hottest in High-Temp Coatings! In addition to providing great looks and
lasting durability, JET-HOT also helps you get more performance from your
vehicle! The insulating quality of the ceramics is the key. When parts are
coated inside and out, JET-HOTwill lower under-hood temperatures by 30=B0F=
or
more. The coating does this by holding the exaust heat inside and will
actually increase the flow enough to add three to seven horsepower to an
average motor.
>SWAIN TECHNOLOGIES: http://swaintech.com/header.html
>Swain Tech Header Coating is different than All the other header coatings.
It is applied as SOLID Ceramic Layers, not hi-temp paint. It is a true .015
thick Thermal Barrier.
> Other header coatings are .002 thick and meant for appearance and
corrosion resistance. Swain Coating is Functional not Cosmetic.=20
>White Lightning Coating
>Swain Tech Thermal Barrier Coating, TBC-EX -- TBC-EX is a 3-layer
.015-.020" thick permanent coating. The coating is pearl white in color and
extremely durable. It reduces radient heat by more than 50%. (It is NOT
>>Thomas:
>>You claim that "... the performance guys seem to buying Swain coatings and
>>the show car and street crowd seem to be buying Jet-Hot".
>>Not the picture from what I see below, in a previous e-mail message. =
Looks
>>to me like there is a probably a sharing of the wealth, and I haven't seen
>>Jet-Hot's "propaganda/claims yet. So how does one justify pitching one
>>coater over the other at this point based on product and application??????
>>By the way, I'd still like to learn your numbers for heat reduction for=
the
>>other two coater's you mentioned compared to Swain's claim????
>> Paul Bartz
>>From: Chuck Will [mailto:willa]
>>Sent: Tuesday, December 15, 1998 1:14 PM
>>To: gmcmotorhome
>>Subject: GMC: [Fwd: Jet Hot vs. HPC]
>>Cory at HPC so here is his response. Thanks Chuck
>>Chuck:
>>Not a problem. I get asked this very often. Jet-Hot is the same type
>>coating as HPC. HPC's owner was an engineer at an aerospace company that
>>applied these coatings on parts of jet engines. In 1981 he saw an
>>application for these coatings in motorsports (his first love, he was a=
drag
>>racer prior to entering the Air Force and flying F-105's in Vietnam) an a
>>way to get out of the government end of things and be his own boss.
>>In 1982 HPC was opened in Oklahoma City. Since then we have opened
>>facilities in CT, UT, AZ, two in Australia and one in New Zealand.
>>Jet-Hot's owner left the same aerospace firm in 1991 and opened
>>MCCI/Jet-Hot. Since then they have opened facilities in PA, MS and AZ and
>>Australia. Is there a pattern here?
>>Like I said, the ceramic-metallic coatings are similar. We manufacture=
our
>>own coatings in our Utah facility. So the formula can be different.
>>Independent testing has shown that on the average our coating runs 25%
>>thicker than theirs and has longer corrosion protection. The thermal
>>properties are the same. Now our HiPerCoat Extreme(tm) that you and I=
spoke
>>of is 5 times the insulation but very expensive. Jet-Hot has nothing like
>>this. Your friend has been reading too many of their ads (That's why I am
>>with HPC. I am a marketing guy trying to turn that around. Jet-Hot has
>>done very good in "buying the market" in the last six years).
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
>To: gmcmotorhome
headers
>=20
long time.
also?
>Rapid cool-down.=20
>Weldability.=20
or
average motor.
>>Thomas:
Looks
the
>> Paul Bartz
>>To: gmcmotorhome
>>Chuck:
drag
our
spoke
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
