Can people post exterior roof pics please if they have them.....i need to compare it to mine so i can see whats different.
Nope thats not mine...i think thats Mike's.Yep, that is exactly where my vents are located. BTW, are you doing this work on the unit that is completely gutted but has a new pretty engine pictures (in the build thread)? If you are starting with a clean slate, you have a significant advantage. By that I mean that you don't need to worry about making 90 degree bends in the existing tank vent fr to "move" the pipe to the outside of the coach. Plug that hole right on the tank and drill a new hole on the side from where you intend to run the piping upward to the cap.
That pretty (but not running yet) engine one is mine.Yep, that is exactly where my vents are located. BTW, are you doing this work on the unit that is completely gutted but has a new pretty engine pictures (in the build thread)? If you are starting with a clean slate, you have a significant advantage. By that I mean that you don't need to worry about making 90 degree bends in the existing tank vent fr to "move" the pipe to the outside of the coach. Plug that hole right on the tank and drill a new hole on the side from where you intend to run the piping upward to the cap.
hi 6cuda6,
here is one of our '76 EL2 after removing the roof pod:
this one came with both ACs and front vent fan. if possible, post up one of what you have.
