One more "fix" for loose races is knurling. On the hubs, it requires an
internal knurling tool, on the spindles, it would require removing them
from the bogie arms, chucking them in a lathe, then replacing them. The
process could correct loose hubs.
78 GMC ROYALE 403
> Thanks Rob, Good info. Next time will try myself.. Liked the experience
> feedback from form. PriceLess
> > G'day,
> > I reckon it would be a good idea to check with the "horses mouth" so I
> sent an email to Locktite USA and got the response below.
> > Regards,
> > Rob M.
> > The Pedantic Mechanic
> > Sydney, Australia
> > AUS '75 Avion - The Blue Streak TZE365V100428
> > USA '75 Avion - Double Trouble TZE365V100426
> > USA '77 Kingsley - TZE 267V100808
> > From: AG - Mike Smigel [mailto:
mike.smigel]
> > Sent: Thursday, April 26, 2018 1:52 PM
> > To: robmueller
> > Subject: Henkel Inquiry - Case #: 00264172 [
> ref:_00
D301RJ1._5003412lmXP:ref ]
> > Rob, I would look at Loctite 640 which you have the option of purchasing
> through an automotive aftermarket distributor as ordering
> > item # 37424 (6 ml tube). The latter is sold through stores like
> O'Reilly's, PepBoys, NAPA or Auto Zone. This is used to augment
> > press fits, but also used for loose, slip fits up to 0.007" on the
> diameter.
> > Regards,
> > Mike Smigel
> > ___________________________
> > Subject: Bearing Race Locktite
> > Description: Gentlemen, I have a 12,000 lb GMC Motorhome that has a
> press fit outer rear wheel bearing race that is spinning in the
> > hub. Can I use one of your products to lock the race to the hub?
> > Thanks,
> > Rob
> > Date of inquiry: 4/26/2018
> > Company: Overkill Engineering
> > Contact Name: Rob
> > Contact Email: robmueller
> > Contact Address: 2284 Gemini Street,
> > City: Houston
> > State: Texas
> > Zip: 77058
> > Country: USA
> > Contact Phone: (832) 331-6467
> > Case #: 00264172
> 1973 26' Canyon Land (Mello Yello) (TZE063v101302)
> Full Time GMC Nomad ('98 NL 2 USA)
