Jim, how about bringing it to New Mexico, along wiht some windshields.
Al
> Dan,
> Funny you should bring this up, Thom is right, this is the exhaust system I
> have on the "dumpster". I have a great many ideas but have not wanted to
> try stuff out on customers coaches, maybe I should change the name of my
> coach to "lab rat"!
> I made up a "Y" pipe with no mufflers and tied it directly to the rail
> pipe. I did not use 3" pipe, the rail pipe was aluminized so I kept the
> pipes OEM.
> At the rear, I turned the pipe 90deg. and put on a low restriction muffler
> with 2 ouput pipes from a big block V8 late model car, nothing expensive or
> fancy. I have 2 pipes peeking out from under the driver side rear.
> Now, you want to know how it works? The major noise I hear is the fuel
> sucking through the carb.. It really sounds like a pushed from the driver
> seat! No muffler noise under the floor, no heat from the muffler, man it
> works super!
> You may have to think a bit about the sewer dump hose, mine has no holding
> tank, but I think you could horn the muffler back there.
> The trip to the rally told me the idea does work and that I want to try it
> out on other coaches. Give it a try, the first test subject lives!
> Come see the "dumpster" in all of its glory any time in Orlando- free
> admission!!!
> Jim Bounds
> >This is exactly what Jim Bounds did to his 'Dumpster' that he drove to
> >Myrtle Beach. Sounded different, but good. Jim may haver some
> >observations from his trip on this setup. (Spotlight of Jim.............
> >> It is time to replace the mufflers on my Palm Beach and had the
> >following idea.
> >>delete both mufflers, have muffler shop make custome Y-pipe connected to
> >main pipe
> >>going to the back and install a low restriction performance muffler such
> >as the super trap.
> >>I am not concerned about a bit of rumble as long as it isn't excessive.
> >The mufflers are the
> >>low point on my GMC (thats why one of them is on a shelf in my garage!)
> >and this setup
> >>should add a few inches of clearance and drop a few pounds.
> >>My logic could be flawed so I would appreciate any input.
> >>Dan Vanderknaap
> >>"Loud" 76 Palm Beach
> Jim Bounds/Co-op Motor Works Orlando
www.gmccoop.com
