Hi Don,
Well all of the Bolts left are rounded, So resigned
to cutting them off
Will still try rapping on them with a hammer after
the Manifolds are off.
See Ya,
Rob
> -----Original Message-----
> From: owner-gmcmotorhome
> [mailto
wner-gmcmotorhome]On Behalf Of Donald W.
> Miller
> Sent: Thursday, October 22, 1998 11:13 AM
> To: gmcmotorhome
> Subject: Re: GMC: Exhaust Manifolds
> I suggest penetrating oil, then heating, etc as it is much easier than
> getting them out after you break them.
> You might want to try the following on your broken exhaust studs:
> 1. If any of the stud is sticking above the head put a nut on top of
> the stud and weld the nut to the stud.
> Keep the nut slightly off the head so there is a little room
> between them.
> 2. Now take a heavy hammer and give the stud a couple of hard hits
> straight on like you are trying to drive it
> through the head. This helps loosen the threads.
> Finding room to
> swing the hammer may be a problem.
> Good luck
> Don Miller
> Shenandoah Valley of Virginia
> >Date: Thu, 22 Oct 1998 09:21:16 -0400
> >From: "robteed"
> >Subject: RE: GMC: Exhaust Manifolds
> >OK. Should I heat them also. I Have a Mapp/Oxy
> > set I got from Home Depot. Gas only last about
> > 10 min when cutting. A little longer when just
> > heating.
> > Rob Teed
> >> [mailto
wner-gmcmotorhome]On Behalf Of Thomas G.
> >> Warner
> >> Sent: Thursday, October 22, 1998 9:04 AM
> >> To: gmcmotorhome
> >> Subject: Re:GMC: Exhaust Manifolds
> >> You need to soack them a lot with a penetrating oil before you try and
> >> remove them.
> >> >I'm trying to get the Exhaust Manifolds off
> >> > the 74' 455 engine. What a Pain! Broke the
> >> > head off two bolts, Got Two out Sucessfully,
> >> > Six Left. All with striped heads. Im planning
> >> > to use a cutting torch to get the rest. Will
> >> > the post left after cutting the heads off be
> >> > very hard to remove????? Has anyone broke one
> >> > off at the block???? Thats My main Worry!
> >> >Thanks,
> >> > Rob Teed
> >> > 74' Painted Desert
> >> > Lansing,Mi
