Tom,
I would never use an impact wrench on something like that. With my luck I would
be drilling out most of the broken bolts soon after using the air wrench. Yes I'm
grown and yes I would be crying.
I feel better using my own touch and feel to get it close then a torque wrench to
make sure.
I just came back from checking out the manifold bolts and most of them were
loose. I tightened then to a little more then 25 lbs and the noise is
diminished. Maybe I fixed my problem?
Richard
> Richard if you really like to see a grown man cry, just put those exhaust
> manifolds on using an impact wrench. YOu will surely break off some studs.
> They are only supposed to be torqued to 25 ft lbs. Tighter and you are
> asking for trouble.
> tom
> >Gene!
> >> I think this is a sign of the times
> >Your web site says "MANIFOLDS You got-em, smoke-em. (military slogan from a
> >despicable drug habit) If you have good exhaust manifolds, resurface them,
> >remount with copper gaskets, and put them on with an impact wrench. Retorque
> >them some time, if you think of it. They worked for 30 years maybe they will
> >work a while longer. If you want them to last longer on our crappy gas, put
> >in an A/F gauge and
> >get your carburetor fixed until the exhaust does not run lean and hot. When
> >the manifolds crack, go to
> >headers.
> >I have potential problems with my exhaust manifolds. I'm getting ready to do
> >a R & R and am wondering about the gasket material to use. Cinnabar used
> >something other then copper and they were the last ones to have worked on my
> >manifolds. One was replaced with a new one and one was resurfaced. The
> >manifold job lasted about 15,000 miles. They're just starting to make
> >noise. I figure I better do something before it gets worse the heads get
> >ruined. I never retorqued them as suggested. I did have the carb
> >recalibrated by Cinnabar at the same time.
> >I am really wondering about the wisdom of using an impact wrench to put them
> >back on. Can you expand upon that recommendation a bit? I normally don't
> >like to use impact wrenches to put stuff on with.
> >Richard Waters
> >1976 PB
> >Troy, MI
http://www.california.com/~eagle/engine.html
> >> gene
> >> >Went to fix exhaust leak yesterday and discovered driver side manifold
> >> >broke into. So far have 4 bolts out and one rounded off. Hope to get
> >> >it out today. What I need is new or prefferably good used left
> >> >manifold. Seems like someone was looking for same last week. Anyone
> >> >have one, any leads, hints, ideas. thanks
> >> >Bill.
