Rick,
I would not install that type of exhaust manifold gasket. If it is a FelPro
#90021 or similar it has a poor fit and you will be replacing it much
quicker. Cinnabar in newsletter #14 stated to avoid that type of gasket
and use the FelPro 1439 gasket. That is the one that I uses along with
Permatex Ultra Copper high temp silicone gasket maker. I lightly apply
a coat of the silicone and then torque the bolts to 25 Let set for 24
hrs before starting engine. This will allow the sealant time to cure.
But sure that you use something like never-seize on the bolts to prevent
them from seizing in the heads. Another alternative is to go to the
solid copper gasket. It is a Mr. Gasket brand that is available from
Jeg's under part # 720-7170 $31.99. The FelPro 1439 is $28 bucks, so
the choice is yours
J.R. Wright
GMC GreatLaker
Michigan
> The two first noticible problems when we got our coach were the lack of a
> dipstick (or tube) and a major exhaust leak. Those two are going to be
> corrected this weekend.
> I opted to order the "Toronado" short dipstick, still available from Olds
> ,about $17.00 for both stick and tube. I'll have to raise the floor to check,
> but thats OK.
> I had the manifold magnafluxed, and finding no cracks had it machined as it
> had warped some. Painted it with header paint (olds blue)...new bolts and
> studs.
> Question??? The new gasket has a "graphite" side and a shiny metal
> side...does it matter what side goes to the block and what side goes to the
> manifold?
> "Rick"
the choice is yours
J.R. Wright
GMC GreatLaker
Michigan
> but thats OK.
> studs.
> manifold?
> "Rick"
