When I removed my stripe, just a few months ago, I used the " ABN Rubber
Eraser Wheel 4in Pad & Adapter". After much trial and error, this is what I
found: The eraser wheel works best when used at relatively low speed to
peel the decal off. It's like using you thumb to roll a decal off once you
get a corner off. In other words I always attacked the edge of the decal,
with the wheel trying to lift the decal, slow and steady pace. Once you get
a feel for it, it goes rather quickly (again relatively speaking). I would
just attach the decal for an hour a night. It took me about two weeks at
this pace. I should mention that there were a couple of spots where the
decal was really really adhered to the paint mostly below the drivers and
passengers side windows. For these areas I was getting frustrated with the
pace of the progress and so started to use the heat and razor blade process
to good effect. Although for the heat I would just use the eraser wheel to
heat up the decal by making a few passes over the leading 1 inch where I
was working. You have to be careful with the razor blade though because the
paint also gets a little soft and the razor blade can dig in and quickly
take you to the primer (just more body work getting ready to re-prime).
Rich
On Wed, Oct 30, 2019 at 5:43 PM Larry Davick via Gmclist <
> I had removed the stripes from the driver's side using my cordless
> electric drill. It was certainly spinning faster than my plug-in drill
> that is
> limited to 1,000 rpm. The wheel I used says not to exceed 4,000 rpm, but
> I don't remember if the faster drill was any more effective than the slow
> drill. They both worked well.
> I do recommend having good light so that you can carefully watch what's
> going on. The stripe adhesive is clear and without careful inspection it
> can
> be missed. It comes off as easily as the stripe.
> Larry Davick
> A Mystery Machine
> 1976(ish) Palm Beach
> Fremont, Ca
> Howell EFI + EBL + Electronic Dizzy
