Entry Handle
gene
2,215
Entry Hand Grip
I have really liked these chrome lighted hand grips since I saw them on the
big guys motor homes and I think on old
Mello Yellow.
I finally found them on sale for $25 each and when I tried to order them,
you guessed it, out of stock.
So here is where you can get them - not on sale. Get the one without the
light, it is easy to put in any light inside the
chrome bracket and saves a lot of money. I wanted two, one outside and one
inside, but at this cost I just put one inside.
http://www.flemingsales.com/html/brightbar.htm
Now still looking for a cheap one for outside.gene
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
can I look at these on the web??
gene
>In a message dated 10/31/1999 10:17:52 AM Central Standard Time,
Gcbr
>writes:
one
>Gene
>Just got back from Auto Zone. They have them. They are $24.99.
>They are 16 inches long and the plastic handle is 1 inch dia.
>They use a molly system to mount so you do not need access
>to the back side Part # 57-8021. Thats what I know.
>Take Care
>Arch
mr.erf
thank you very much for the reference.
I will go see If I can look at it on the net. Also got a pointer to a
store in Or. with some .
gene
Gcbr
>writes:
one
>Gene
>Take Care
>Arch
mr.erf
Just right !!!
I have a porch light that detects movement, I am going to have that turn on
the light on the step,porch light,grab handle,and floor lights. This way ,
when you come in at night, you can see the key slot, step,interior
switches, and floor.
gene
>While you are tinkering around with the door handle, you might want to
>consider adding a light down low by the side of the door to illuminate the
>step at night. I used a clearance light and robbed a clear lens from the
>propane compartment. We found that the original porch light being above the
>belt line did not do much to light the step area.
>Justin
mr.erf
