Should your thermostat stuck shut, you'll not know.
> In these days of heavy traffic, and "distracted driving incidents", I
> figure that systems like the digi-panel that have visual and auditory
> alerts with flashing lights and warning chimes should suffice. I am not a
> proponent of gages that require that you take your eyes off the road. We
> travel a great deal up and down the Interstate 5 corridor between San
> Francisco, California and the Canadian border. Some of the most congested
> roads most of you will ever encounter. Absolutely no place to be taking
> your eyes off the road. Portland, Oregon, Olympia, Tacoma, Seattle,
> Everett, Bellingham all are high speed choke points that go from 70 mph to
> Zero in a hurry. Just me, your situation might differ.
> Jim Hupy
> The main difference is what side of the thermostat do you want to be on.
> Radiator/coolant temp is important but engine temp is more important.
> What do you want to do if you have a stuck thermostat?
> I am a data guy, I vote for both engine temp and return coolant temp.
> > In your case, there shouldn't be much difference if the port is near the
> > top radiator hose. For me, the stock location, as well as the stock gage
> > works just fine. The stock gage is known to be only an approximate wild
> > assed guess, but that seems good enough for my needs. A high mileage 403,
> > well broken in, doesn't make enough heat to worry about for me. But, if
> you
> > have a tight 455 with great compression, and some head and block milling
> > done, your needs might be different than mine.
> > Jim Hupy
> > > Thanks Jim
> > > The rad port is right next to the water inlet uptop on the rad.
> > > If it was yours, where would you mount it?
> > > Thanks, scott
> > > Scott Nutter
> > > 1978 Royale Center Kitchen, Patterson 455, switch pitch tranny, 3.21
> > final
> > > drive, Quad bags, tankless water heater, everything Lenzi.
> > > Houston, Texas
> > > _______________________________________________
> > > GMCnet mailing list
> > > Unsubscribe or Change List Options:
> *John Phillips*
http://www.appliedgmc.com
