'Engine Water' light flickering
dave stragand1
319
Hi All,
When my coach is running, the 'Engine Water' light (coolant level) will
often flicker on and off. The actual level of coolant in the radiator
is fine. My guess to the most likely cause is the coolant level sensor,
which at $10 or less seems worth trying. Does anyone have any
suggestions?
-Dave
1978 Transmode near Pittsburgh
The guru of Chemicals might have some input on the conductivity of various
concentrations of anti-freeze. You might have a problem with the additive
package, or, you might have a problem with the sensor electronics in the
warning light circuitry.
Salem, Oregon
On Wed, Sep 18, 2019, 10:47 AM Dave Stragand via Gmclist <
> Hi All,
> suggestions?
> -Dave
> Hi All,
> When my coach is running, the 'Engine Water' light (coolant level) will often flicker on and off. The actual level of coolant in the radiator is
> fine. My guess to the most likely cause is the coolant level sensor, which at $10 or less seems worth trying. Does anyone have any suggestions?
> -Dave
Dave,
I have known this to be the connection to the probe in the tank getting bad. Before you do anything rash, pull the wire off the probe and clean
both.
I recall that mine would also flicker on a cold start but go away after the engine warmed up. This was before I had the radiator re-cored. I have
not noticed it since. This may suggest a bad connection that was inadvertently repaired when I reinstalled the radiator.
Larry Davick
A Mystery Machine
1976(ish) Palm Beach
Fremont, Ca
Howell EFI + EBL + Electronic Dizzy
If I remember correctly that sensor is nothing more that a brass or steel probe sitting in the water / coolant. I will go with the others here and
say your problem is the wire going to it or the connection.
Crimp the slide on socket gently.
When it flickers on senders, I say connection is the issue.
On Thu, Sep 19, 2019 at 12:50 AM Ken Burton via Gmclist <
> Ken Burton - N9KB
> 76 Palm Beach
> Hebron, Indiana
http://www.appliedgmc.com
Thanks to all who replied with suggestions! It indeed was simply a
loose connection at the switch.
-Dave
