Engine Runs Hotter than usual
I have founfd no difference with the water wetter when used with 50% glycol AF. I have no experiance with Evans.
However on marginally cooling hot rods I have found straiht water with water wetter to cool the best. Dont think thats really viable in the GMCwith
long term corrosion and WP issues.
Anyone have an actual inrovement with AF? Does it have a synergistic effect with Evans?
76 Glenbrook
Have you tried water alone? Probably the same as with water wetter. But not good from a corrosion viewpoint. Also, no antifoam, water pump lubricant or rubber/seal anti swell properties.
Emery Stora
> 76 Glenbrook
Do you have an intake hose running to the front? My old one partially collapsed one time and the temps spiked right away. Where are you guys going
through the Rockies?
1977 Palm Beach, 455, mostly stock and original
