Please note, the forum recently had a problem with outbound emails for notifications, registrations, etc. A new email provider has been set up which should resolve all email issues. If you have any further trouble, please DM Christo or reach out via the Contact Us link in the website footer.
It should be straight with the centerline of the engine parallel to the centerline of the coach. But it should also be off-center, shifted to the passenger side.
There are also two motor/transmission mounts at the rear of the assembly bolted to a piece bolted to the frame. If the engine has actually shifted, some or all of the rubber in those mounts should be visibly damaged.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
